Scratch Build – In Progress Falqoon one - Sneak preview!
Discussion in 'Project Logs' started by Falqoon, 14 Apr 2020.
  1. Falqoon
    Falqoon Minimodder
    13 May 2013
    About the project
    For "falqoon one" I wanted to do an open chassis build. Making every hardware part of the build completely visible. I'm a hardware enthusiast, so I like to really like to look at it. I've designed the base of the build, and the rest will take shape while building. The downside of this, that everything of the build needs to be very tidy! While everything is visible, the cables, or at least the middle section of every cable will be hidden inside the 3cm thick frame. I also designed this build not specifically for this hardware. Meaning, that I can swap the motherboard, gpu etc without effecting the cable routing etc for these parts. The motherboard will have 1cm standoffs, so all the motherboard cables will go underneath so routing will be always as tidy as possible. It's not my idea to make Christmas out of it, so it will not be a fully RGB build. In the end it may have some lighting, but only to complement the build.
    Hardware
    Current hardware list for this build:
    • AMD Ryzen 5 2600
    • AMD Radeon 5700
    • ASRock B450M Pro4
    • 16GB Crucial Ballistix Sport LT
    • Kingston A2000 1TB
    • Corsair AX860i
    • pci-e 3.0 x16 riser cable
    * red is still needed/wanted
    Water cooling
    Current water cooling list for this build:
    • Corsair SP 120 fans (4x)
    • Alphacool NexXxos ST30 240 radiator (2x)
    • Alphacool NexXxos XP cpu waterblock
    • Alphacool compression fittings
    • Alphacool VPP655T pump
    • AMD Radeon 5700 waterblock
    • Reservoir (tube / pump top combi)
    • Flex tubing
    • Hard tubing
    • Hard tubing fittings
    • Other fans
    Materials
    The most of the build will consist of aluminium. I will use aluminium square tubes for the frame, and aluminium sheets for the motherboard tray / back. Besides aluminium, a friend of mine has made his 3D printer available to me. This means that I will try to design some cool 3d printed parts as well, and try to make them look factory made by sanding them down and spray painting them.
    Sponsors
    Currently, this build is not sponsored yet, but I'm definitely open for a partnership.
    Photography
    As my biggest hobby is Photography, it will play a big role in this build as well. However, product photography is new to me, my usual shots are about motorsport and landscape. I'll try to do my best for you guys! The camera and lenses that i will use for this build is as following:
    • Nikon D500
    • Tokina 11-20mm 2.8
    • Nikon 50mm 1.8 D
    Studio
    At the end of the build (or maybe even in between) I will do the final shoot in the studio. While I don't have a studio, I will turn my living room upside down, set up the studio lights etc.
  2. Falqoon
    Falqoon Minimodder
    13 May 2013
    Reserved for final pictures
  3. Falqoon
    Falqoon Minimodder
    13 May 2013
    Post 1: Design
    This will be the assembled frame, without components:
    The frame itself:
    Exploded view:
    Corner piece I designed to assemble the frame, and get rounded corners for some elegance:
    Enjoy the ride!
    Jean R built and Cheapskate like this.
  4. Falqoon
    Falqoon Minimodder
    13 May 2013
    Post 2: Sneak preview!
    Check this out! My friend Joost made me some awesome corners. Check out the small video of the process!
    Dot_Kappa likes this.
  5. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Love the concept keen to do this one day. I'd be more impressed seeing that inner frame made from a single piece. none the less this is really cool.
  6. TempeMod
    TempeMod What's a Dremel?
    1 Apr 2020
    Nice 3D render, looks a bit like thermaltake p3 and similar open cases
  7. Falqoon
    Falqoon Minimodder
    13 May 2013
    Thanks! Yeah, one piece would be cooler, but would also require a lot of material!
    Thanks man! Yeah everything has been done already to date, so will have some similarities to other cases hah, we get inspired by what we like most!
