Modding Fan adaptor for the hole where normally a PSU would go?
Discussion in 'Modding' started by wywywywy, 9 Aug 2011.
  1. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Hi all,
    Basically I am using a PicoPSU with a Dell AC adaptor in the HTPC, so it leaves a big hole where a PSU would usually go. Normally this wouldn't be a problem, but the case hasn't got much air flow right now - it is designed to rely on the air flow of the PSU.
    So I am wondering, is there any bracket/mount/adaptor that would allow me to fit a fan there to aid air flow?
    Except chopping up a perfectly good PSU obviously!
    Thanks.
  2. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Maybe lian-li has a cover for their dual psu case ... Lemme check.
    Edit : sowwy, did not have any luck. All I was able to find is psu mountig bracket. I think that the best would be to build one yourself
  3. Xye
    Xye What's a Dremel?
    21 Nov 2010
    Yeah just need to print out a template of what you would like and stick it to some material to cut out.
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    find bit of aluminium plate cut to size drill vent holes or mount a fan think be best bet
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Personally I would bag an old busted PSU from somewhere (maybe ebay) and gut it so there is nothing in there apart from the fan, preferably at least a 120mm fan and a psu that isn't made of mesh.
    The fan inside is usually connected with the normal 3/4 pin connector so you may need to run a fan lead extension.
