Electronics Fan Connectors.
Discussion in 'Modding' started by Bluephoenix, 2 Apr 2007.
  1. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I've been looking for the molex part codes for the 3-pin and 4-pin fan connectors for a while now, and have indeed used the search, yet they still elude me.
    anyone care to educate me?
  2. Bluephoenix
    3 Dec 2006
    still no luck after searching for 2 days....
    anyone know where I might be able to find out? the help would be greatly appreciated.
  3. Bluephoenix
    3 Dec 2006
    nevermind, finally found the info.
    they are three distinct parts
    Female housing: Molex KK series Part No. 22-01-3037
    Crimp connector [3 inside each housing] : Molex KK series Part No. 08-50-0114
    Header terminal: Molex KK series Part No. 22-23-2031
    hope you all find the info useful.
  4. Cinnander
    Cinnander What's a Dremel?
    19 Apr 2007
    Hi, had a hell of a time trying to find a supplier for these! Didn't think Rapid sold them, spent most of a day searching... RS carry them but you have to order 5+ or 10+ depending what you want, and they're overpriced -- same as maplin, at £1+ for the 4 pin molex plugs, and around the same for the 3 pin KK headers. (Maplin's molex plugs are suitable for use on the end of cables only - I was after PCB-mountable ones, and Maplin don't carry the 3 pin KKs at all).
    Turns out Rapid DO carry them (ARGH!), they're hidden away under Cables & Connectors > Multipole > PCB Interconnect > 2.54mm Straight Header.
    Also PCB Interconnect > Disk Drive Connectors (I swear I searched for this -- Rapid, your search sucks!)
    So, if you're looking to buy either Mate-N-Lok sockets or connectors (commonly called 'Molex plugs' - HDD power plugs) or the Molex 3-pin fan headers then both are available from Rapid (UK).
    4 Pin plugs & sockets
    3 Pin headers
    3 Pin sockets (goes on the end of the fan cables)
  5. Bluephoenix
    3 Dec 2006
    I use digi-key since I'm across the pond, but the molex # is universal since they're the supplier.
  6. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    I have like 30 of the 3pin headers that are just desoldered from old (sometimes new) dead motherboards. It is always a good idea to salvage whatever you can from old boards, Stuff like the usb ports, serial ports, usb pin headers, headers in general, dip switches, and fan headers.
    Most board's have at least 2 fan headers, and many have 3 or more. I use my butane torch lightly on the back of the board and the header falls right off. You dont have to worry about damaging the board, its already dead :thumb:
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    There are lots of other makers of these and often a Molex number isn't quoted even if they're genuine Molex. Rapid do both Molex™ and the cheaper JYK™ range; Maplin sell them unbranded as '0.1" Series Straight Plug PCB Header' and '0.1" Series Socket Housing'; Futurlec call them '3 Pin .100" Straight Male Polarized Headers' and '3 Pin .100" Polarized Header Connectors', no brand given; but virtually every on-line parts supplier has equivalents.
    "I was after PCB-mountable ones, and Maplin don't carry the 3 pin KKs at all" - BX96E
  8. Cinnander
    19 Apr 2007
    To clarify, those were two seperate statements, oops. I meant 4 pin Mate-N-Lok sockets for use on PCBs, AND as another point maplin don't carry th 3 pins ones at all ... but clearly they do! Thanks for that anyway! I'll bear those in mind if rapid ever go out of stock
    Edit: OK which of you buggers bought them all :p
