Fan control
Discussion in 'Hardware' started by craig, 22 May 2002.
  1. craig
    craig What's a Dremel?
    6 Mar 2002
    Does anybody know if you can buy the small fan control unit that is monuted on the lian li cases seperately, as id like to control my rear fan (and the blow hole when i musta the courage to cut this baby up). i no you can make them but i like how compact the one they use is. if you cant buy it i guess ill just have to make me another fan bus.
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    i don't think so but you best bet will probably be a baybus or a slotbus....
    www.baybus.co.uk will make you one if you send them your blanking plate and they don't charge much either.
  3. Marzupial
    Marzupial What's a Dremel?
    29 Oct 2001
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    yeah, as marzupial said...best thing is to make your own...looks much better aswell...
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    and the sense of pride you get - i did that all by myself i did! :D
  6. craig
    6 Mar 2002
    yeah guess ill have to make another one. i asked lian li and they said they dont sell it seperatly.
    just gotta get me some more stripe board.
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    it looks easy enough
  8. craig
    6 Mar 2002
    yeah it is, just was gonna save some time. spoze if i want the best for my Lian Li ill have to do it myself :D .
  9. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    well i have the exact same case as you and that fan controller seems simple, i'm sure you could knock on up easily, the only thing that annoys me is having to rip the front off to change the fan speed :rolleyes:
  10. craig
    6 Mar 2002
    yeah i think it is, but i might try creatin a couple that run off ir or rf so its inside the case and out of site :D:D:D
  11. felix the cat
    11 Jan 2002
    nice one...get some wiring diagrams drawn up and then post em for us to have a look at...
