Hey, Yes, Noob. I bought a fan controller but it has no cables with it, and i only have 4 pin molex fans can someone point me in the direct of a cable that will let me control my 4pin molex fan with my fan controller that only takes 3 pin fans. I bought some off the bay, but i must of bought the wrong ones. Thank you, Mark.
This is the fan controller i have; http://www.tomshardware.com/reviews/front-mounted-ports,684-13.html
These are the two connectors :- 3pin end 4pin end Of course you could always make your own from the components that KustomPCs stocks. Note: I'm not employed by KustomePCs, just a satisfied customer.
You don't need to see the end. The description says "Allows you to use a 4pin molex fan on a 3pin motherboard header". Which is what you want. You want to convert the molex to a 3pin. And the connector on the back of your fan controller is the same as a motherboard header.
