Modding Fan controller switch
Discussion in 'Modding' started by Brooxy, 2 Sep 2006.
  1. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    I have a 4 way fan controller in my PC, akaska thing, which controls the case fans on my case, and it does a very good job of it.
    However, at night I leave it playing music, and casefans are not really needed, nor is the brightblue lighting within...
    Put short is it possible to cut the power to the fan controller with it on, via a switch, without messing anything up? It's powered by the molex a floppy drive would use...
  2. Skylined
    Skylined Minimodder
    3 May 2003
    You can wire the controler's "output" to the switch, and the fan wired to that switch.
  3. Brooxy
    20 Apr 2006
    Problem with this, if you cut power to the fan, the controller goes mental and starts screaming at me with beeps...
  4. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    unplug the controller and all fans and controller will turn off...
  5. Mr_SCSI
    Mr_SCSI What's a Dremel?
    13 Apr 2004
    You mean the controllers "Input" to the switch, right?
    Turns off controller, no beeping or power to fans.
    Job done.
    Do it with my DigiDoc5
  6. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Just put a switch on the 12volt line from the molex. drill a whole apply switch somewhere int he hole and make it prettyful.
  7. Skylined
    Skylined Minimodder
    3 May 2003
    I think that you're messing with the RPM cable, and that's why you get the beeps.
    On a fan, the yellow cable is RPM, red is (+) and black (-)
  8. Mr_SCSI
    13 Apr 2004
    Sounds like he's cutting the 12v... but this means no rpm signal as well so sets the alarm off anyway.
  9. hydro_electric_655
    13 Jul 2006
    Just cut the 12 volt mains to it. end of story.
  10. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    Well if it uses both 12V and 5V then I would suggest getting a DPST for both lines, and if you only have a SPST then connect both grounds to the switch.
    -CollinstheClown
  11. Mr_SCSI
    13 Apr 2004
    Exactly what I said earlier. :thumb:
  12. Brooxy
    20 Apr 2006
    Okies, just making a mount for the switch, and then it'll all be good, thanks guys :hip:
