Fan controller; which one?
Discussion in 'Hardware' started by fannypad, 26 Oct 2006.
  1. fannypad
    fannypad What's a Dremel?
    27 Nov 2003
    I'm looking for a low cost four-channel fan controller with simple rotary controls that makes it simple to switch four 12V fans to 7V or 5V and back again.
    Any suggestions?
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    The Zalamn one, very well built and works well.
  3. Amjedm
    Amjedm Minimodder
    2 Sep 2003
    Just in case you haven't bought one, I recommend the Sunbeam Rheobus.
    Very little modding required - just push the LEDs back.
  4. nazomcg
    nazomcg Minimodder
    4 Aug 2006
    I've got the zalman, works fine, looks good. One thing i would say is that it was a big of a bu**er to install and wire up, especially between my two dvd drives.
  5. fannypad
    27 Nov 2003
    Where can I buy one in the UK?
    And can you confirm that it does indeed have the option to turn the fans down to zero (off)?
  6. Amjedm
    Amjedm Minimodder
    2 Sep 2003
    I didn't get an email notification, sorry.
    I think out of stock in the UK at the moment - www.kustompcs.co.uk used to have it in.
    You can try the following from the US though
    http://www.jab-tech.com/Sunbeam-5-1-4-Rheobus-Kit-Silver-pr-2529.html
    Will come to under £18 inc delivery so no VAT or other charges to pay.
    I have the Silver one and it does allow you turn the fans off completely.
  7. fannypad
    27 Nov 2003
    Excellent, cheers for the info :)
    Ends up being a bit pricey from the yank retailer, but it compares well with the Antec controllers which seem to be the only ones out there that can handle a similar wattage per channel and can shut the fans off.
  8. Amjedm
    Amjedm Minimodder
    2 Sep 2003
    No probs :)
    With regards other fan controllers - I heard about buzzing from Vantec Nexus controllers + not sure if these can be turned off.
    I also have a Coolermaster Aerogate II which I got for around £12 (IIRC). You can't turn the fan off as the lowest is 7v. I suppose the 7v is a safeguard so you don't end up switching the cpu fan off.
    I didn't think under £18 was too bad a price as I think it would work out to more than that from Kustom.
