hi im gettin the controversial Viper case and it has 7 expansion bays how wud i go about connectin the fans to a fan controller that i put in the bay??? (im new to the scene )
Buy the controller you want, then follow the installation instructions. Some have 3 pin connections, some have 4 pin, and some require bare ended wires for screw terminals. It should be sraight forward.
I've only used sunbeam and homemade ones. The sunbeam is ok and cheap. search for fan conrollers and you will find oodles of info in these forums,
If you just want manual control and aren't using hugely high-power fans, anything will do. I use a cheap'n'simple one as I that was all I needed. (GBP7.50excel)
