Cooling Fan Controllers...
Discussion in 'Hardware' started by foxpoo, 9 Aug 2010.
  1. foxpoo
    foxpoo Thumb it in
    28 Apr 2010
    Morning all,
    I've decided I want to incorporate a fan controller into my new machine, which is pretty much the July premium player build. I've never dealt with them before, but assume I plug the PSU into the fan controller, and the fans power plugs into the fan controller too? Can anyone suggest a good controller?
    Cooler Master ATCS 840
    XFX Black Edition P1-750B-NLG9
    Asus P6X58D-E DDR3 Motherboard
    2.8Ghz Intel Core i7 930 @ 4Ghz
    AK-CCX-4002HP Venom CPU Cooler
    6Gb Corsair XMS3 DDR3 RAM
    XFX ATI Radeon HD 5870
    Corsair F120
    2 x Samsung Spinpoint F3 1TB
    Sony AD-7260S-0B 24x DVD RW
    Asus Xonar DX
    Razer Lycosa Mirror Special Edition Gaming Keyboard
    Many thanks for any help.
  2. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    With fan controllers there isn't really much between them, other then number of fans, so almost anything will do. And yeah, most will take a molex input from your PSU, and output to 3 or 4 3pin fan connectors.
  3. foxpoo
    foxpoo Thumb it in
    28 Apr 2010
    Many thanks, I'll go for the sexiest controller then! :eek:)
  4. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    I just got a NZXT in my Cosmos build, controls 5 fans with 5 temps and works great! Sometimes I think it runs the fans a bit low, and if you set the target temp lower it beeps to tell you it has reached it. Otherwise is GREAT!
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Loads of extra wires, thats the only downside to them.
    Put one in my sons new build and with the case I chose for him its a nightmare to hide them all, already had the fan controller that I pulled from my daughters pc because it didnt play nice with her led fans (made them flash) other wise I would have just let the mbo take care of fan speeds.
  6. wejjy
    wejjy Minimodder
    9 Aug 2010
    I had a Zalman ZM-MFC3 in my old setup, worked really well, and looks kinda classy too!
  7. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    I have this one which was easy to set up and looks great:[​IMG] [​IMG]
    Voila: [​IMG]
    You can also link multiple fans to each of the 4 dials on the controller using fan splitter cables (eg 2x front fans to one, 2x top, 2x rear, 3x radiator etc) and it has 4 temperature probes to put anywhere inside or out of your case.
    There's also another version with brushed aluminium instead of clear plastic: [​IMG]
  8. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    I'd recommend Scythe too. Generally: reasonable price and do the job, while looking nice.
    I picked up the Scythe Kaze Server myself.
  9. Altron
    Altron Minimodder
    12 Dec 2002
    Another plus for Scythe.
    I have one of their cheap basic ones - 3.5" drive bay, four knobs, no temperature controls or displays. It works real nice, and included four 3-pin fan connection extension cords so all of the fans reached it neatly.
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I have the Kaze Master Ace 5.23" and its lovely, big +1 from me.
  11. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    That's my one, nice but one time I found that at the levels I set it to sometimes my fans would judder instead of spinning, they needed a little extra juice before they'd fully start up. Also don't get this if you have people round that you know would be tempted to touch your fan controller, this baby does have an off posistion that WILL turn the fans off so I'd recommend not having your CPU fan attached.
  12. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    +1 for the scythe.
    Just installed on in my system. Does wat it says on the box
  13. Bloody_Pete
    11 Aug 2008
    My mates always do that, because it's 'funny'. They don't find it so funny when I'm hitting them with things...
  14. Aracos
    11 Feb 2009
    If anyone even mentions my fan controller I shout "DON'T TOUCH IT!" They get it pretty much instantly. It's not even like it's funny in the slightest and people don't find it funny when they turn it low enough for the alarm to go off. It's certainly a loud alarm.
  15. Altron
    Altron Minimodder
    12 Dec 2002
    My Scythe Kaze doesn't go low enough to turn any of the fans off, but I guess every fan varies. I do have my CPU fan on it. I also have the auto-shutdown enabled in the BIOS if the cpu gets too hot.
  16. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    kaze Q here, small and understated =]
  17. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I use an Aerocool Touch 1000, since my case has a door on the front I can't have big knobs sticking out of it or it wouldn't close :)
  18. Parge
    16 Jul 2010
    I have a NZXT Sentry 2.
    Its quite bling-ish, and I'd say is very good at auto regulating fanspeed, but harder than it should be to turn up or down individual fans because of the lack of physical knobs.
  19. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    I've got the original dual-bay Sentry - love the big screen but HATE the thermal probe system. I hope and pray for a fan controller that takes its temperature information from the motherboard/GPU/HDD temperature sensors as appropriate.
  20. Bloody_Pete
    11 Aug 2008
    Ditto, so many annoying wires floating around the case, plus its hard to get a good reading as the temp will vary depending where the probes are placed.
