Build Advice Fan/electrics specialist?
Discussion in 'Hardware' started by 4004, 19 May 2021.
  1. 4004
    4004 What's a Dremel?
    19 May 2021
    This isn't exactly a PC build, but maybe I can get some recommendations for places (ideally in the south, I'm in Berks).
    What I've got is a ventilation kit for my car, which was made by Webasto for BMW.
    It's an array of 6 IP44-rated axial fans, a voltage converter (the thing is powered by a solar panel), supercapacitors and a controller board.
    Can anyone recommend a place that would be able to upgrade some of these bits, eg the fans, capacitors?
    I am thinking there are efficiency gains to be had, and maybe some new tech, eg a fan with a built in temp sensor.
    Thought PC-build places might help, but they all seem to be either very specialised (the consumer ones) or focused on the commercial/industrial market (likely won't take on a one off).
    cheers
