Motherboards Fan Error?!
Discussion in 'Hardware' started by pyro1son, 21 Jan 2012.
  1. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    After installing a new AM3 motherboard everything was going well until it unexpectedly shut down, after trying to reboot i got the error message telling me that the CPU fan had an error, obviously i could tell that the fan is spinning so what could the problem be?
    While i wait for your advice I'm reapplying thermal paste and resetting the cooler in an attempt that this will help.
    Thanks for the help,
    Pyro
  2. longweight
    7 May 2011
    What temps are you getting in the BIOS? Very strange error message!
  3. pyro1son
    18 Aug 2010
    it now doesn't go into BIOS so i can't find out the temps! looking like RAM may be playing a part in this.
  4. longweight
    7 May 2011
    Ooo weird! Sounds like a classic case of knocking something whilst having a play. Sure everything is seated properly and all power leads are snug?
  5. pyro1son
    18 Aug 2010
    I'll give them all a wiggle! I WILL GET THIS TO WORK!
  6. longweight
    7 May 2011
    Ha I don't envy you working through it! Good luck!
  7. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    i had that problem once before...never did find the exact cause...but disconnecting EVERYTHING, and re-seating the cables made the problem dissapear...so i guess one of the wires wasnt making contact
    its possible that the pwn / fan speed wire isnt connecting, so the fan is getting plenty of power and spinning up, but the mobo cant detect it
  8. izools
    izools What's a Dremel?
    28 Dec 2011
    Fan error is usually because the motherboard either can't sense the fan spinning, or because its spinning below the minimum threshold configured in the BIOS.
    My motherboard, for example, won't accept a fan RPM below 600 as "acceptable", as the top fan in my case spins at 600RPM at most (spec - more like 590RPM realistically) I get a POST error unless I disable monitoring of that fan in the BIOS.
    Same thing perhaps?
  9. feathers
    feathers Minimodder
    11 Apr 2009
    Yes, some motherboards will shutdown if CPU fan returns zero. Is it a PWM 4 pin fan or 3 pin fan?
    Some motherboards can have fan speed bugs. Gigabyte I had would report fan as disconnected sometimes until I rebooted. Had to disable the fan alarm in bios. It was a mobo bios bug because my brother had same mobo and he had same issue.
    Gigabyte never fixed that with a bios update. Bios updates came and went but they never fixed that bug.
    Obviously first thing to do is check the CPU temp. You should always have software installed under windows to show CPU temp.
    I use Speedfan utlity which also allows me to take control of all the fans automatically according to temperatures of various parts. I can also set speedfan to shutdown PC if something fails or overheats.
    It's bad practice not to know what your CPU temp is.
    If you determine that the CPU temp is normal then you can safely say the issue is a typical Gigabyte one of misreporting fan speed. You should be able to disable automatic shutdown in bios of the fan signal returns zero.
    Shutdown should be based on CPU temp more than fan speed especially with a buggy Giga board.
  10. T2I3M
    T2I3M Minimodder
    13 Mar 2010
    I have a similar issue. The only way round it for me was to disable the monitoring in BIOS. :(
  11. pyro1son
    18 Aug 2010
    Reseated everything and redone all the power cables but still nothing can't even get into bios!
  12. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Got a different PWM fan to play with ( from a spare reference cooler or something )?
  13. pyro1son
    18 Aug 2010
    Ill try that but its not looking good!
  14. feathers
    feathers Minimodder
    11 Apr 2009
    Sounds more like a part overheated and burned out. CPU I guess.
    If it was simply fan speed fault you could get into bios.
  15. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Have you tried taking the entire system out of the case and setting it up on the desk?
    When I got my Rampage III recently and installed it for the first time, my system wouldn't power up. Why? Because the back of the motherboard was shorting on the inside of the case.
    Definitely worth checking, as taking the motherboard out of the case is high on the list of troubleshooting priorities. :thumb:
  16. pyro1son
    18 Aug 2010
    Im suspecting the CPU has given up! :(
  17. feathers
    feathers Minimodder
    11 Apr 2009
    Agree.
  18. Max Tractor
    Max Tractor Minimodder
    15 Jan 2006
    Is this the Asus
  19. pyro1son
    18 Aug 2010
    Yep no luck so far
  20. Max Tractor
    15 Jan 2006
    have you cleared cmos?
