Modding Fan filter
Discussion in 'Modding' started by k-e-n-2, 30 Mar 2009.
  1. k-e-n-2
    k-e-n-2 What's a Dremel?
    25 Mar 2009
    Hi all!
    I have a Thermaltake Armor+ MX case with a 230mm fan on the left side. But there's no filter on it, lot of dust coming in my case!
    How can I build a filter for that big fan?
    Thanks!
  2. Conan1257
    Conan1257 What's a Dremel?
    2 Feb 2009
    Tights... they work very well...
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Make from a dryer sheet?
  4. jhanlon303
    7 Sep 2006
    I've seen on other forums where people used "Swiffer" sheets cut to fit(bigger than dryer sheets but don't smell as nice). I tried it and it works well on the front intake on a Lian-Li.
    john
  5. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    I've heard that a lot of people use women's stockings stretched tight over the intakes... not sure how effective it is though, I should really do that with my Armor...
  6. HAFMaster
    HAFMaster What's a Dremel?
    25 Jan 2009
    A couple more options:
    "NoSeeUm" mosquito netting
    Room Air Conditioner filters
  7. jhanlon303
    7 Sep 2006
    One other thing. As a home owner with pets, I spray our furnace filters with 'Enddust' on the input side before installing. The Enddust tends to really pick up pet hair and bird feathers before they get sucked in. We change filters every 2 weeks to 1 month.
    john
    PS: The Enddust works a marvel on picking up stuff from hardwood floors. Swiffer+Endust = win!
    john
  8. k-e-n-2
    25 Mar 2009
    Nice one! I also have a pet ^^
    Thanks for all your answers! I'll try stockings xD But how do I build it :confused:
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    3 layers of mosquito-net works best imho.
    1x horizontal - 1x diagonal - 1x horizontal
    Then a little frame made out of alu to attach the net to.
    Finished removable dustfilter.
    As those mosquito-nets come in white, grey or black usually, there'll be a colour that matches your case.
  10. k-e-n-2
    25 Mar 2009
    Thanks jrs77,
    Looks nice =D
    But where do I find the aluminum??
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    Aluminium-sheets can be bought in nearly every home depot.
    Or you look for a cheaper supplier like metal-workers, etc. A square-foot of 2mm aluminium-sheet is somewhere around 5 Euro there.
  12. jhanlon303
    7 Sep 2006
    Here in the US you can look for wire mesh wastebaskets and office trays. You can find them new at Target and Wally World. Used from the thrift and charity stores. Silver, black and even a pink Hello Kitty mesh have come through here.
    john
  13. jrs77
    jrs77 Modder
    17 Feb 2006
    Good idea there aswell, allthough the mesh is a little bit too big for my taste. The mesh should be maximum around 0.5mm to act as a dust-filter.
    The mesh I used there in my pictures is 1mm, that's why I'm layering it 3 times.
    EDIT: Another good option is to use the stuff that speakers are covered with :idea: The stuff is called Sonotex RT -> http://www.intertechnik.com/index/shop/1347335.html and comes in various colours.
  14. Elton
    23 Jan 2009
    Speaker Covers are actually a great idea(never thought of it, ironically I have tons of speakers).
    Also if you have a pool and one of those underwater vaccums, use the filter in those, there are even finer than most.
  15. Mantronic
    Mantronic What's a Dremel?
    5 Jan 2009
    What I would consider
    I think if I were making my own dust filters I'd make them out of a wire mesh like aluminum or stainless steel so they would be easy to take out and clean. I could only hazard a guess at what the percent of open space you would need so as not to impede airflow too much. I think if you used something like THIS it would probably manage to do what you want pretty well.
  16. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    0.075" seems like quite big spacing, that's 1.9mm in the metric world.
    It would be improved if you used a few layers ontop of each other, slightly offset so the holes don't line up. You'll need to be careful not to fill the airflow though.
  17. docodine
    docodine killed a guy once
    10 Feb 2007
    @fast1: It's a computer case..
    I use regular dryer sheets, though I hate how they look. They work great though.
