Modding fan help 80-90
Discussion in 'Modding' started by darkhunter, 1 Oct 2004.
  1. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    ok i was being stopid a while ago and ordered 80 mil fans instead of 90 is there any way i can fix this with like minimal if no cutting or makeing of stuff
    in other words is there a 2 second fix for this that will last me a long time
  2. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    this is a tad bit expensive but
    http://www.frozencpu.com/cgi-bin/frozencpu/duc-06.html
    but you can find converters like this. i wouldnt recommend ordering those because of the price but shop around
  3. darkhunter
    13 Apr 2004
    ok thanks but yeah at that price i min as well return and get the 90s also thermaltake says that its fans and cases are 90 instead of 92 mill is there a difference
  4. f U z ! o N
    1 Feb 2004
    im sure you could find cheaper ones if ya looked
  5. darkhunter
    13 Apr 2004
  6. f U z ! o N
    1 Feb 2004
    vantec tornadoes sound like hair dryers just to let you know
  7. darkhunter
    13 Apr 2004
    ya i know but i have my "computer room" in a closet that has some srious insulation you can barely hear my 300 watt spaekers if u put ur ear to the wall so i dont care
  8. Go4t
    Go4t i
    13 Dec 2003
    tornados are nice and you can always undervolt them if they are too loud
  9. 0013
    0013 What's a Dremel?
    7 Mar 2004
    As far as i know , 90 and 92 are the same ... i ve got a couple of 90 mm and 92 mm labeled and they are the same size...
  10. SilentDeath
    SilentDeath What's a Dremel?
    28 Jun 2004
    You might try running a zip tie through the fan grill to the screw holes of the fan. Sure, it's not the greatest way around the problem, but it's the quickest (and more importantly, cheapest!) fix that I can think of.
  11. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    yah silent death nailed it, glue and tape are the other 2 options (for the longest time my 120mm fan was taped to my radiator
