Disaster Fan hole a bit too big...
Discussion in 'Modding' started by BluFluX, 26 Mar 2002.
  1. BluFluX
    BluFluX What's a Dremel?
    26 Mar 2002
    --not authorized to search so i dont know if this has been discussed before... sorry if it has--
    Dremel busted a couple weeks ago, so I decided to try a bit more unorthodox ways of inserting a hole into my computer case.... interestingly enough i did a pretty good job. The hole looks almost like a dremel did it (only took two hours to do, ack) anyway, its a bit too big and sticks out like a sore thumb with the fan over it...
    Any methods for repairing a 125 mm hole intended for a 120mm fan? (I can attach it so its just the sides that are out of whack)
    I did get another dremel btw... I thought about moving the fan over to one side about 5mm, cutting another spot for another fan, and just attaching another right next to it.
