Guide Fan Hole & Radiator Template Downloads
Discussion in 'Modding' started by mnpctech, 22 Feb 2009.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
  2. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Saved in my folder of "random templates" cheers bill :rock:
  3. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    wow thanks a lot, ill print them out later.
    this will save me so much time.
  4. jhanlon303
    7 Sep 2006
    This helps a lot. The ones I have are from the Netherlands and want to print on A4 paper.
    Thanks
    john
  5. newbie
    newbie What's a Dremel?
    24 Apr 2009
    Cheers for this mnpctech will make my life a lot easier when i start to plan my 1st case build from scratch,
    appreciate it
    Dave
  6. talladega
    talladega I'm Squidward
    18 Aug 2007
    although the thread is old thanks for bumping it because i didn't know this was posted. i need these very soon. thanks!
  7. jhanlon303
    7 Sep 2006
    Too bad Bill doesn't have a 2x40 radiator or fan template.
    Just kidding. Langer and I seem to be the only customers for this technological aberration.:D
    john
  8. mnpctech
    21 Apr 2003
    a Modder in Canada asked if I could sell him some 60mm fans. So youre not alone, (ok, off by 20mm)
    LOL, you always bring cheer john :D
  9. mnpctech
    21 Apr 2003
  10. KRAZY KEV
    KRAZY KEV What's a Dremel?
    25 Dec 2009
  11. mnpctech
    21 Apr 2003
    No prob Kev, glad you can use them :thumb:
  12. Mojo
    Mojo Multimodder
    18 Nov 2011
    sorry for bumping this... but any chance you have a 60mm template?
    have tried google but no such luck :waah:
  13. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Could we maybe sticky this?
  14. mishmash
    mishmash What's a Dremel?
    12 Dec 2011
    This was worth me joining alone, many thanks man :)
  15. mnpctech
    21 Apr 2003
  16. jhanlon303
    7 Sep 2006
    I could still use a 2 X 40mm template and a nice 25mm grill. Just sayin.
    john
    I was not here. We did not have this conversation.
  17. Mojo
    Mojo Multimodder
    18 Nov 2011
    i too could also do with a 40mm template :p
  18. mnpctech
    21 Apr 2003
    :worried:
    lol
  19. Guest-23315
    Guest-23315 Guest
    Used your 240mm radiator grill template earlier Bill, worked a treat and stopped me faffing about for hours with rulers.
    :thumb:
    mnpctech likes this.
  20. mnpctech
    21 Apr 2003
    Cool, E.E.L Ambiense made these for Mnpctech, so you know they're perfect!
