Electronics Fan RPM wire: how?
Discussion in 'Modding' started by relix, 19 Feb 2002.
  1. relix
    relix Minimodder
    14 Nov 2001
    How do these RPM sensing wires work? How do they "transmit" the RPM? Is it with lowering/highering the voltage on it? Sending a pulse or something? Thanks!
  2. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    this one took me a while to work out but basically you get a square wave out of them but you need to plug them into a load i think (i just used an and gate) then you get 2 pulses per revolution
    hope this helps
  3. Phalanx1
    Phalanx1 What's a Dremel?
    14 Feb 2002
    well, to be exact, the rpm output wire doesn't give out a pulse signal. It just goes from being HZ (high impedant) to Ground 2x per rev.
    So it goes: HZ - Ground - HZ - Ground .. (you get the picture) :)
    That's why u'll never measure any voltage on that wire if you connect a voltmeter to it.
    And i think it uses a Hall-switch (which reacts to magnetic fields, usally south-poles) to do this switching.
    So in short, if you want to be able to measure this signal with a frequency meter or something, you have to use a pull-up resistor with the rpm wire.
  4. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    Phalanx you from AT?
  5. eaterofpies
    12 Feb 2002
    well you get a square wave out thats really the only thing that matters
