Planning Fan shroud or air chamber?
Discussion in 'Modding' started by novaris, 28 Sep 2010.
  1. novaris
    novaris What's a Dremel?
    10 Oct 2006
    I've thinking about a wc setup for 1 of my case mods and I am quite concerned about the use of shrouds on fans and rads.
    is it better for a fan shroud or an airtight chamber where 3x120mm fans blow air into then on the other side is the radiator itself?
    basically 2nd part is like the fans having indirect contact with the radiator....
    thanks.
  2. capnPedro
    11 Apr 2007
    You want your fans a small distance away from your radiator (if possible, it's not essential) to minimise the "dead spot" caused by the central hub, but you don't want them too far away or you lose some static pressure.
    A shroud is essentially a air chamber of optimal dimensions anyway.
  3. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    As said, yes b shroud would help, cut not essential. I don't bother in my setup. for a shroud to be effective, it probably needs to be at least an inch deep. Diminishing returns above that. A deeper rad would be better choice, unless you have extra space to use up.
