Cooling Fan Shrouds
Discussion in 'Hardware' started by Da_Rude_Baboon, 2 Dec 2003.
  1. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Anyone know where i can buy a 120mm fan shroud for my rad or do i have :dremel: one myeslf?
    Thanks,
    Da_Rude_Baboon
  2. Conrad
    Conrad What's a Dremel?
    23 Jul 2003
    use an old 120mm fan or buy a cheap one and hack out the centre bit, ie the fan blades and support brackets to them. mines works a treat ;) [clickme]
  3. Risky
    Risky Modder
    10 Sep 2001
    Yep thats my plan - unfortunately the first cheap fan I found turned out to be too nice and I had to buy another before I was willing to destroy it. Project in progress atm.
  4. Nexxo
    23 Oct 2001
    How you approach such a problem depends on the size and mounting method of the rad as well...
