Electronics fan wire question
Discussion in 'Modding' started by bard, 12 Apr 2003.
  1. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    On those fans you connect to the mobo, there are three wires. What does the third wire do?
  2. RTT
    RTT #parp
    12 Mar 2001
    RPM wire? :)
  3. bard
    8 Mar 2003
    Can I somehow alter the RPM with this wire?
  4. Reflex
    Reflex What's a Dremel?
    8 Dec 2002
    it doesnt control the rpm, its shows the mobo how fast its spinning. Each time the fan makes 1 revolution a pulse is sent along the wire which the mobo counts and translates. Well soemthing like that anyway :p
  5. bard
    8 Mar 2003
    Ok. But this wire isn't essential for the fan to work, right?
  6. RTT
    RTT #parp
    12 Mar 2001
    Nope, not essential :)
  7. bard
    8 Mar 2003
    Could I just connect the RPM wire to a fan connector on the mobo, but still run the electric wires to my custom fan connector on my bezel? (I make it sound so nice. It is just a molex with a switch and an LED)
  8. RTT
    RTT #parp
    12 Mar 2001
    yep
