Electronics FANBUS schems needed *special
Discussion in 'Modding' started by bee2643, 16 Apr 2002.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    I need schematics for a fanbus. not just ANY fanbus, but a fanbus using potentiometers
    heh
    i have 6 fans and 6 potentiometers, how would i wire 1 fan upto 1 potentiometer, etc.
    note: the potentiometer has 3 pins
    pics would be a bonus, making sure that you clearly label the top and the bottom (of the potentiometer) so i dont get the pins b0rked.
    elimination of the resistor would be hardcore ;)
  2. cderalow
    cderalow bondage master!
    23 Jan 2002
  3. bee2643
    7 Mar 2002
    hrm...i was hoping perhaps someone whos bored could draw me a personal schem
    i will credit them :dude:
  4. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Ok, here we go :blush:
    http://www.bit-tech.net/article/52/5
    The "even more advanced" fan control circut is probibly the best of both worlds, easy to build, and good results.
    As for the pot, if you don't like the way it turns (say turns right to increce voltage to fan, and you want it to turn left to provide more voltage to the fan), just switch the 2 outer pins.
    No custom schematics, but hope that this gives some help!
    Signing out...
  5. bee2643
    7 Mar 2002
    ARGGGG
    i asked for a simple one useing only pots
  6. Yo-DUH_87
    6 Mar 2002
    Ok, the "basic way." :lol:
    http://www.bit-tech.net/article/56/
    There is no schematic, but this one is so easy, you should be able to draw it in your sleep :yawn:
    Are you happy now :eyebrow: The only real modification you would need to make to this if you wanted to build one of those "power distribution/rehobus" units, you'd need to make a couple simple changes, again, you should be able to draw those changes in your sleep :yawn:
    If this is not what you want, try describing in more detail what you DO want :hehe: :lol:
  7. macroman
    macroman The One
    3 Sep 2001
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Before you start connecting wire A to pot B, what value resistance and wattage are these pots you've got?
  9. macroman
    macroman The One
    3 Sep 2001
    Re: Re: FANBUS schems needed *special
    I wondered how long before you asked. ;) :D
  10. Yo-DUH_87
    6 Mar 2002
    I'm hoping that they are somewhere between 20 and 50 ohms, otherwise, bee2643 will need more pots, or a aditional few resistors (R1*R2/R1+R2).
    Signing out...
  11. viridius
    viridius What's a Dremel?
    7 Apr 2002
    Also, if you are working with potentiometers, short one pin on the edge to the middle terminal. I can't tell you which without a pic and an explanation of the resistance change, but that way, if the wiper breaks, the fan will continue to run.
  12. Tado™
    Tado™ What's a Dremel?
    21 Aug 2002
  13. bee2643
    7 Mar 2002
    use image006 and draw your own...not hard :eek:
