Modding Fanmounts from Aluminium leftovers
Discussion in 'Modding' started by jeckulz, 20 Jul 2011.
  1. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    So my last mod was cutting a dirty great hole in my case panel.
    Beltin, looks good.
    Lately I've not had much cash (wife-to-be at uni - Expensive), but I have had a 40cmx40cm square of brushed aluminium sat around not doin anything. Raiding my spares box I found a foxconn 90mm fan and a dusty old adda 80mm fan.
    This is what happens when
    Povertyxboredom+(fans+aluminium+dremel)=DIY fan mounts!
    Heres the intended locations.
    Here to pull cool air through the meshed front 5" bays
    And one down here to pull air from the open back of the case and point it at my GPU fan
    It was raining, so armed with a fan to blow the dust outside, and a cat to oversee my work, I began to lay waste to the aluminium sheet.
    I used cardboard as mock-up pieces after measuring to ensure they fit correctly, then layed these out on the aluminium as stencils which I marked out with a sharpie.
    After a few dremel discs and a coffee later I was left with these. Note the card mock-ups.
    I left the ally cut outs over a radiator for a bit to warm up ready for bending.
    After burning my middle and ring finger, I put some gloves on and began bending using 2 huge sheets of MDF to sandwich the metal where I wanted to keep it flat.
    Without going into too much detail, after a while I got these
    And I was pretty happy. Untill I realised I have nowhere to plug the fans in :duh:.
    So all in, this will cost me £2.40 tomorrow for a pair of fan splitter cables.
    Here they are all mounted up anyway
    Not really a MOTM nominee, but it kept my hands busy for a few hours.
    Thanks for lookin.
  2. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Thats actually really nice.
    I think thats a great idea and made well also.
  3. jeckulz
    18 Jan 2011
    LOL cheers. Nipping out for the fan cables in a bit, I'll put some temps up.
  4. BrokenJaw
    BrokenJaw What's a Dremel?
    16 Jun 2011
    The PCI slot one is a genius idea, looks really nice too.
    Now if only there was some way of reversing it so it sucked all that nasty hot air from the GPU
  5. jeckulz
    18 Jan 2011
    Thanks! :D
    Spose you could if you reversed the wires in the plug for the fan on the GPU? Ive still got warranty on the GPU, so I wont be doin that :p
    Right, idle temps are in.
    Not done any load readings yet, but with ambient @ around 25 degrees.
    All these were with fans at settings as quiet as possible.
    Im getting
    CPU- 31 degrees down from 34 - Helped along by 90mm fan(standard clocking with an Asus silent square 2. Dont ask WHY standard clocking- BIOS and Mobo are a POS)
    GPU- 60 down from 62. (HD 6850 OC'd by about 15 percent with auto fan control) Helped by the 80mm fan
    With all fans on full (wind tunnel mode) all other settings same,
    Im seeing
    CPU @ 30 and GPU @ 59!
    Im quite happy with that :D
    Temps recorded on Core temp taskbar monitor and MSI afterburner task bar monitor. Fluctuations of +1/-1 degree were observed, but not sustained.
  6. BrokenJaw
    16 Jun 2011
    I didn't quite mean make the fans spin in reverse. Most fans only work when rotating in the correct direction.
    What I meant was making some form of shroud that sucked in the exausted hot air from the GPU and pushed it outside of the case.
    Nice to see an actual drop in temps. Be intersting to see how it affects load temperatures
  7. jeckulz
    18 Jan 2011
    Cant be too hard.
    Would make quite a bulky addition to the back of your case though, you could easily apply the same principle as my internal mount, but just make it inverse and aim the fan upward.
  8. KidMod-Southpaw
    28 Sep 2010
    Ballocks, I was after some brushed alu :lol:
    Well, school's out now, and a new project waits for me to get going on. Maybe you could do one too and we'll have a little wiganer competition in MOTM :thumb:
