Cooling Fans and WD-40
Discussion in 'Hardware' started by sik wit it, 5 Jul 2004.
  1. sik wit it
    sik wit it What's a Dremel?
    1 Jul 2004
    My chipset fan on my abit IC7 is strangely whiny, and I figure if I sprayed some WD-40 on it it could easy up the ball bearings and silence the whining.
    My question is, could WD-40 on the bearings of the fan or dripping slightly onto my mobo be dangerous?
  2. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    just a tine little bit.. :hehe:
    i`d give it about 5 seconds b4 the WD-40 dripped onto the mobo and killed it..
  3. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    True. WD-40 is Kerosene based and besides conducting electricity is also combustible (keep clear from sparks, then...). Silicone lubricants do not have these problems however. Or Molybdenum Disulfide, but try and get your hands on that...
    The problem with lubricant however is that it is sticky to dust particles, so they are more likely to collect and clog up your fan.
    Besides, a whiny fan is usually a dying fan. Just replace the little sucker (blower?) for a nice Zalman passive heatshink to solve your problem and experience longer lasting quiet mobo joy! :thumb:
  4. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    WD40 will also disolve the greese in the bearing if there is any. Silicone lube, as nexxo said, is the way to go but it will need checking periocially.
  5. Twunka
    Twunka What's a Dremel?
    12 Feb 2004
    i use WD 40 in my fans every 4 months and leave them out for 3 hours after spraying into them and they are quiet as hell
  6. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    I think we are missing the most obvious issue....IT STINKS!
    spray that near a fan your going to be smelling WD-40 for a couple of weeks :/
    'doc
  7. Risky
    Risky Modder
    10 Sep 2001
    I've used sewing machine oil which seems ok.
  8. fivecheebs
    19 Feb 2003
    [ot]
    :jawdrop: is there something wrong with me? ... I LOVE the smell of WD. Not as nice as burnt 2 stroke though (especially with castrol R additive).
    [/ot]
  9. Jedi
    Jedi What's a Dremel?
    16 May 2004
    yeh wd40 is basically a solvent, works in the short-term.
    i use a teflon based dry-lube for bike-chains, it's in a bottle not an aerosol so u can apply it with-out plastering it everywhere :D
  10. Nexxo
    23 Oct 2001
    NO IT ISN'T! Sewing machine oil has a habit of attacking plastics. Don't use!
  11. Pug
    Pug What's a Heatsink?
    16 May 2002
    ^^^ Same approach as me. I used WD40 years ago, to discover the same as cheebs (omghi2u! ;)) and Nexxo, in that it dissolves any vestiges of the original grease. Then I discovered the teflon-based bike grease (I used Finish Line, by memory), peeled back the sticker over the fan bearing with a scalpel and squidged a bit in before replacing the sticker. Shut it right up for months. :)
    [Edit] Mmmm, Castrol R... :hip:
  12. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Any light oil will probably attack plastics, some more than others. It's just really a question of it it really matters much, or if you care.
  13. fivecheebs
    19 Feb 2003
    Mmmm = Understatement .... When i smell it i have a tiny orgasm ... does that make me odd? :worried:
  14. wharrad
    wharrad Minimodder
    26 Jul 2003
    Just get a new fan.... The one on my NB just died after wining for awhile, I've got the same mobo and all. Thinking it's just 'cos the smaller fans are a touch rubbish
  15. Jedi
    16 May 2004
    ooooh eerie, finish line here too :hehe:
