Internal I/O Connectors: 1 x Floppy Drive Connector 1 x Front Audio 1 x CPU FAN 1 x System FAN 1 x Chassis FAN 1 x Case Open Connector 1 x AUX_IN 1 x CD_IN 1 x IrDA 1 x S/PDIF 1 x Game Connector 2 x USB Port What do those fan things mean? What's a system fan vs a Chassis fan? Also does this mean I can only have three fans in my computer total? Is there a way, without really soldering anything, that I could have more? (Ideally, I'd like to have 4 case fans) http://www.newegg.com/app/viewProductDesc.asp?description=13-137-050&depa=0
All that means is the total number of 3-pin fans you can have plugged into the motherboard. You can have any number of fans plugged directly into the PSU, either directly or with 3-pin to 4-pin adapters.
So if I wanted to plug them into the PSU would I have to plug them into a molex plug (and would that require an extra cord?) or are there ones on the PSU that are made for that size? BTW I'm getting an OCZ Powerstream 520W PSU. http://www.newegg.com/app/viewProductDesc.asp?description=17-104-152&depa=0
If the fans are terminated with a 3-pin connector, you'll need an adapter to plug them into your PSU. If they use a standard molex connector, then you can just plug it straight into one of your PSU's molexes.
