Modding Fans in Serial(?)? So many questions and brackets
Discussion in 'Modding' started by WheresMyBeard, 3 Dec 2009.
  1. WheresMyBeard
    WheresMyBeard What's a Dremel?
    3 Jul 2009
    I have a 120mm fan intake at the front of my case, and wondered if there were any advantages to have 2 fans running in serial (one directly or close behind the other)?
    I hope that it may increase airflow or pressure of air coming in? (I hope so as my graphics cards need some nice cool air so they don't fry)
    Will it just put a strain on the fans somehow?
    Is there any interesting science to this? (Any graphs appreciated! I <3 graphs)
  2. capnPedro
    11 Apr 2007
    If a fan is on a radiator, having an empty fan (i.e. the frame with the blades removed) as a spacer removes the fan's "dead zone".
    Otherwise, stacking fans is kinda pointless. The easiest (but not completely correct) way I can explain it is, after the first fan, the air is moving at the fastest speed it will move. A second (identical) fan will not accelerate it further, because it's already as fast as possible (for that fan to move it at). There's no increase in static pressure, because there's no increase in velocity and ergo no increase in flowrate.
  3. stuartwood89
    20 Aug 2008
    Makes perfect sense to me. I guess that using a shroud would also increase efficiency in CPU heatsinks and the like?
  4. capnPedro
    11 Apr 2007
    Yeah, very much the same principle, normally you're a bit more limited with space for a HSF, though.
  5. WheresMyBeard
    3 Jul 2009
    Thanks for your responses.... I'll rethink my plans
  6. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    You might see fans set up like this on some enterprise level equipment, but AFAIK, it's done mostly for redundancy.
  7. motas
    motas What's a Dremel?
    7 Dec 2009
    What happens if you have a section like this:
    fan->radiator->fan->radiator->fan
    would that cool all the radiators well?
  8. Coldon
    Coldon What's a Dremel?
    14 Oct 2006
    just to be pedantic the correct phrase is: "in series"
    afaik, having two fans on tops of each other doesnt increase the air flow but it increases the fan pressure, so its could be useful on high FPI rads.
    Otherwise dont bother...
  9. WheresMyBeard
    3 Jul 2009
    I think you may have a point there Coldon, that is pedantic.
    Just to clarify, this is not for a water cooled system, it is just to see if there was a way to maximise the effectiveness of the air coming in through the front of the case to the graphics cards...
  10. Coldon
    14 Oct 2006
    short of buying a different fan, nope...
  11. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    I tried running 2 fans in series to cool my DLP TV (one before bulb, one after) becuase it kept overheating (causing shutdown) and it didn't help in the slightest. I recently removed the light baffle/air duct (which kept it closed loop) and just used the 2nd fan to exhaust the whole electronics compartment and it hasn't overheated since. Not the best comparison, but its the same idea.
