Graphics FAO 7900GT users
Discussion in 'Hardware' started by Highland3r, 30 May 2006.
  1. Krikkit
    21 Jan 2003
    There's an X1800XT, if you can find one. Other than that you can just buy a 7900GT, if they die, they die in a couple of days. :)
  2. Predalien
    Predalien What's a Dremel?
    21 Apr 2004
    I know the x1800xt would be the chosen if I were to buy an ATI, but it seems to me that the 7900GT is faster. Anyway I can be wrong, as I haven't seen any review with the two of them side by side, any thoughts?
    I just don't want to buy the 7900gt if nvidia doesn't do anything to solve this. Even if the ram sink trick works, I don't like having to do that if I buy one.
  3. Krikkit
    21 Jan 2003
    You only have to do that if you're OC'ing it really, mine was fine for ages without one, and that was with a pretty decent OC (678C, ~800M).
    If they're going to die, they do it in a couple of days, so you'll be able to RMA it straight away without problems. All the shops and manufacturers are ready for it now, they know the issues with the 7900GT's. :)
  4. Predalien
    21 Apr 2004
    Two things seems to be possible now...
    - I buy the 7900GT, everything will be ok if it doesn't die after a few gaming days (Everything?? really, in good health for the rest of its live if I don't OC it?? *me worried)
    - Someone convices me about buying the x1800xt, telling me it equals or surpases the nvidia
    I really hope nvidia does something with this. Even if shops are ready if you want to RMA it, as kirkkit says, it's a pain...
  5. Krikkit
    21 Jan 2003
    Just bite the bullet and be a man. Pick one.
  6. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    my 7900gt ko is running good after a few days of gaming. The ramsink trick helped. those little buggers get HOT!
  7. Predalien
    21 Apr 2004
    After reading a lot I think I'll be buying a 7900GT, but those low prices I have seen for the X1900XT are tempting me... the diference in price between them is reduced by 1/5 for me as I pay with Euros and I'll be buying from TigerDirect
  8. cs_maan
    cs_maan What's a Dremel?
    21 Jun 2006
    so has this soluton worked for anyone yet, i have a XFX 7900gt extreme 520 core and 750 (1500) mem, if so would it work for me
  9. Highland3r
    Highland3r Minimodder
    25 Jul 2003
  10. striker289
    22 Jan 2005
    Well i am also a victim of the 7900gt plague :(
    my eVGA 7900gt ko started to show problems in battlefield 2. I tested it in 3dmark and it freaked out. I ran sinks from day one...
  11. lcdguy
    lcdguy Minimodder
    25 May 2004
    if you get the X1900XT you won't be dissappointed i traded up my 7900gtx (artifacting) for the X1900XT while the frame rates are a little slower it still provides much better graphical detail.
    example i run fear at 1680x1050 with everything maxed out except for softshadows and detailed icons (or whatever it's called) and the frame rates don't dip below 29fps :D
  12. Predalien
    21 Apr 2004
    A x1900XT would be great, but I'm still very interested in the 7900GT. I'll probably end up spending less money when buying everything, and the 7900GT is perfect for that.
    The problems with this card have gone too far, nVidia should do something!!
