Modding FAO anyone with a cheiftech window
Discussion in 'Modding' started by couzo, 18 May 2003.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I was wondering how is the window attached to the sidepanel? Are they attached with rivets or a screw type system?
    Also would it be easy to replace the window of the panel?
    Thanks
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    It is attached with small plasic rivets/clips that you can reuse.
    I had to cut a new window panel for mine after messing up some window tint, and just used the same clips.
    And yes it was easy, just used the original as a template, just make sure you dont drill the holes to large, best make it a tight fit rather than loose.
  3. couzo
    26 Apr 2002
    great thats all I needed to know thanks mate!!
