Electronics FAO Cpemma (Or other such Electronics Luminary) - RE Diode Bus
Discussion in 'Modding' started by GreatOldOne, 4 Nov 2002.
Thread Status:
Not open for further replies.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    My transistor theory is a bit shaky, but it seems from simulations that if the collector current is fixed by the load, base current should be limited to load current/gain.
    That's ideal world, any short on the output would pull a high base current, which a base resistor would limit. So I think they're a safety device. :confused:
  2. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Guys - I'm confused! (Not difficult, I know...)
    The Blue LEDs I was thinking of using have a voltage forward of 5.5v.
    I read in another post that to get the value of the current limiting resistor, I add up the voltage forward values - So off a 12v supply, I'd only be able to run 2 in series, according to the Linear's calculator.
    So how do I get 6 to light up bargraph style?
  3. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    That is a pretty high voltage for an LED.
    (They may be a first generation Blue LED)
    If they are indead that high, yes you can only run two in series.
    To get six you will have to wire two sets of three in paralell.
    Each set will need it's own resistor.
    And the transistor should be able to handle the extra current without any problems.
    If you are worried, or want to run more than one fan off this, you can use power transistors.
  4. GreatOldOne
    29 Jan 2002
    Wouldn't that mean that it'd be all off, 3 on or 6 on? The effect I'm after is a one by one increase in the number of LED's lit.
    Can it be done?
  5. ZapWizard
    19 Sep 2002
    Opps,
    /me looking at schematic again...
    Oh, the LED's light in sequence, so it goes in series through each LED lighting them in turn....
    You have two choices.
    Seperate each LED as runs a resistor for each, this will provide a one LED indicator, showing the current level.
    OR
    Get different LED's
  6. GreatOldOne
    29 Jan 2002
    OK - so next question is does anybody know where I can get blue led's that have VF < 2v ?
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    My diobus circuit takes care of that problem. With those leds you'll need to use 3 lots of 2 in series, with the steering diode arrangement keeping the lower voltage strings on when the switch is in the higher voltage positions.
    So from switch pins 9 and over, a diode and resistor also goes to the pin 8 led to keep the first string on, as well as to the second or third strings. From pins 11 & 12, two steering diodes will be needed, to the first & second string of leds. Gets a bit cluttered, but is possible ;)
    You'll notice even with 2v reds, you need at least 2 strings.
  8. GreatOldOne
    29 Jan 2002
    Great - I'll have thunk and draw up a new schematic.
    Thanks to both of you (Zap & CP)
    GOO
  9. GreatOldOne
    29 Jan 2002
    Right - Here's the latest attempt. This splits the six leds into 3 groups of 2, and the limiting resistors have been calculated using a VF of 5v and IF of 30mA. I've put in Schottky diodes like in Cpemma's switch diodebus to control the flow to the LED's.
    Diode-Bus II Take Two
    Look Ok?
    Ta,
    GOO
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The motor control side looks OK (I'd use 2 diodes at D14), but you've got the display signal coming from the various transistor emitters, which are also grounded, so that's a :nono:
    That said, I can't see where you can connect the display sources suitable for a bargraph with your circuit as it stands. The complex way would be to pair up all the transistors, one in the motor circuit and one in a display circuit, but there may be a simpler method (other than a 3914 across the fan).
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Here's one that may work (caveat actor), added on to the 4017 knight-rider circuit.
    However, a major snag (IMO) is that the circuit doesn't "remember" fan settings when you turn the box off. :sigh:
    A more minor snag is that any fan speed signal shouldn't be used, as fan negative is above ground potential.
    Anyone for PICs? :D
  12. GreatOldOne
    29 Jan 2002
    Fan speed sensing isn't really a big issue for me, as I don't get it on the intakes of my Lili now. Plus I know how fast there going by a) the sound and b) the LED's.
    Cheers for the circuit though! Need a trip to Maplins for supplies! :D
  13. Marvin
    Marvin What's a Dremel?
    21 Jan 2003
    Just to stirr an old topic, has anyone been able to make a pushbutton fanbus that does remember the state it was previously?
    If so, then I would like to know how it can be done. At first I was thinking about ripping some juice from +5VSB line, but thought that it should somehow remember state anyhow
  14. Risky
    Risky Modder
    10 Sep 2001
  15. Marvin
    21 Jan 2003
    yes I have read that couple of times but it does not answer that question, how to remember old state after shutdown. It does have couple of truly nice features though...
  16. OrbDemon
    OrbDemon What's a Dremel?
    6 Jul 2003
    Could you not use something like this.
  17. Marvin
    21 Jan 2003
    Nice one, Orb, You just pointed me to one of my own postings :D :rock:
    The reason I would like to do it 4017 style is that it would be so easy to get leds to display the fanspeed. If this is not possible, then Ill just have to do it with that DS1809 I mentioned in that other posting and attach a LM3914 to it to get bargraph
    Marvin, please start a new thread rather than re-open one that's as old (and not all that relavent) as this one, & oblige cpemma.. :nono:
Thread Status:
