Modding FAO Fly or anyone who might know about spiral wrap
Discussion in 'Modding' started by couzo, 29 Jun 2002.
Thread Status:
Not open for further replies.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    Hi fly saw your Lian-Li a while back and want to get some of that white spiral wrap what sizes did you use?
  2. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    i know the 4.2mm from OCS is perfect for molex power cables and streches round my ATX mobo connector nicely too.
  3. Qbank
    Qbank What's a Dremel?
    19 Jun 2002
    I have looked for it in the local stores
    i've looked for it in the local stores, but you have to bay a whole pakage it costs about 14 € , is it much or not ?
  4. Fly
    Fly inter arma silent leges
    31 Aug 2001
    its for sale in maplin. not much left in the country though.
    BL57
    BL58
    BL59
    for the various sizes.
  5. Floydian
    Floydian What's a Dremel?
    30 Dec 2001
    Do you have a pic of your spiral wrap job? Or a link to it? Always wondered how it looked w/white!
  6. Fly
    31 Aug 2001
  7. binatony
    binatony What's a Dremel?
    22 Jan 2008
    I have used braided sleeve on my cables with heatshrink tubing to tidy up the bird nest of cables. I used to use spiral wrap with self adhesive cable tie bases to hold the cables in a tidy loom along the case chassis. I found it was cheaper getting the spiral wrap and sticky cable tie mounts from a car accessories shop online.
    I bought 2 metres of 5mm Spiral Wrap and Self Adhesive Cable Tie Bases
    Have a good look on google for car accessories shops and you might even find it cheaper with more selection (case modding related) than the shop above.
Thread Status:
