Ive just changed from using winamp to foobar simply because I was fed up with winamps shenanegins and foobar is a lot simpler with a far better playlist. BUT where is the volume control!? I must be going nuts if it's there because ive clicked everything. Windows volume control on my laptop in on the lowest above mute and it's still too loud. I've found file-preferences-playback-volume setup and set it to various points of numbers and negative numbers but it makes no difference
Just use plus and minus on your numerical keypad Edit, for clicky, left click on the dB in at the bottom right
Foobar2000>Preference>Playback - and it's on that screen. It's also possible to get it to display in the bottom right corner(measured in dB) and to raise and lower it with the plus and minus keys. A good tip is to never put it above -4dB, keeps the distortion out. Oh and welcome to the smart side
AWWW SHIIIT. There's me looking at the top where everything normally is! I KNEW it was there somewhere but when you start looking hard you always miss the obvious. Not only that, but this ALWAYS ALWAYS happens to me. I click preferences and straight up what's in front of me: Volume Control. WTF?! I clicked everything (honestly here, no BS) and I couldnt find it. I knew this would happen, it's so frustrating.
