Linux Fast booting distro
Discussion in 'Software' started by hitman012, 7 Jan 2006.
  1. hitman012
    hitman012 Minimodder
    6 May 2005
    I've been having a play around with a few different flavours of Linux and I find that that boot time isn't great. I know disabling the different tasks can speed things up, but are there any that are designed to boot fast out of the box?
    TIA :)
  2. TJK
    TJK What's a Dremel?
    21 Nov 2004
    have you tried GenToo? It's a text based install, and not easy, but both I and friends have had very good luck with it.
  3. simon w
    simon w What's a Dremel?
    3 Nov 2003
    If you haven't got the time for Gentoo, I find that slackware boots fairly quickly :)
  4. specofdust
    specofdust Banned
    26 Feb 2005
    Gentoo is supposedly the uber fast distro of choice, you need to do lots of boring compiley stuff. To be honest, best bet would be to get yourself into the bit-tech(#bit-tech) IRC chan on quakenet, theres a lot of 'nix knowledge floating about there.
  5. hitman012
    6 May 2005
    I'll look into Gentoo and Slackware and perhaps pop onto IRC later (need to install mIRC again). Thanks for the quick replies :)
  6. trigger
    trigger Procrastinator
    22 Mar 2004
    Just to add my 0.02p, I use Debian, and on my Thinkpad R40 (1.2G PM) booting is surpisingly fast: only a minute or so from power on. It has very few services running though, as I just don't need them there.
  7. Jaxx
    Jaxx What's a Dremel?
    7 Apr 2004
    I second what Trigger said.
    If you turn off all the unnecessary crap at startup any distro would be rather fast.
  8. ajack
    ajack rox
    17 Apr 2003
    I've not seen many differences between boot times with different distros (unless of course you cound SuSE which is just slow) - it's all about which services/processes you want to start at boot (for instance the AppleTalk daemon takes an age to start). I'm using Kubuntu atm which isn't the fastest thing to boot, but doesn't particularly bother me since I rarely reboot/turn off anyway.
  9. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    You could also look into parallelizing when services start up.
    If you choose Gentoo, there is at least one thread about it over on their forums. Let me know if you go that route, and I'll see if I can find it.
  10. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    Also don't take the equivalent time it takes to boot windows as a reference. Windows cheats slightly by drawing the desktop before starting most services, so that it looks like you've booted, even though you can't actually do anything.
    Anyway, I recommend Gentoo, because their forums are awesome, the documentation is immense, and Portage is the dog's proverbials.
    Sam
