Motherboards Fast Mobile Charging Motherboard
Discussion in 'Hardware' started by Euro_Bucks, 18 Jan 2017.
  1. Euro_Bucks
    Euro_Bucks What's a Dremel?
    6 Aug 2014
    I have no idea this stuff is possible in PC then I saw a motherboard
    capable of doing this.
    I am not an electrician or something but I totally have no idea how it works.
    Does adding up amp charges your mobile device faster? How will it affect your battery in the long run?
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    My motherboard has a similar feature.
    Standard USB 2.0 port will output 0.5A and most phones now are capable of receiving around 2A
    So motherboards that offer fast charge ports just output more amps that the device connecting can receive.
    If you check your phone charger its likely 5v around 2A so this is safe for the phone. It charges it the same as your phone charger would.
    Edit: Here are my ports connecting to a Sony Xperia z3+
    http://imgur.com/gMh0W5Q
    Standard USB on the front panel it pulls 0.3A
    http://imgur.com/AR6oGqK
    The Fast charging port it pulls over 1A
    Testing my official charger the phone is pulling similar so I may be hitting a limit by my current battery charge. But I hope this provides some insight.
  3. Euro_Bucks
    6 Aug 2014
    I have checked its feature and it says...
    "Lightning Charger
    The new 2nd-generation BIOSTAR RACING motherboards will be the first to have the new Lightning Charger which helps the battery of enabled devices, including smartphones or tablets, to achieve up to 75% charge in just 30 minutes. It supports QC2.0 (12V/1.5A output), Apple Mode (5V /2.4A) and BC1.2."
    I know you are the right person to ask. I have an Asus Zenfone 5 and might get that motherboard in the future. Is that feature really capable of fast charging or just another marketing strategy?
  4. teamtd11
    31 Aug 2005
    From what I can see, your phone does not support quick charge 2.0 but the apple mode would be useful, however it would not charge your phone any faster than your standard charger that came with your phone.
    It would charge your phone faster than none Lightning Charger ports.
    If you had a phone that supports Quick Charge 2.0 you would see 75% charge in 30 mins. When using this board or a QC 2.0 Charger.
  5. Euro_Bucks
    6 Aug 2014
    I checked qualcomm's page to see if my phone supports quick charge 2.0.
    Sad my phone is not on this list.
  6. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    *deleted*
  7. techniana
    techniana What's a Dremel?
    3 Jan 2017
    Thanks for sharing mate. My husband def needed this information right here! :)
