Networks Fast Transfer of Huge Data Need Help!!!!
Discussion in 'Hardware' started by greattechie, 2 Nov 2001.
  1. greattechie
    greattechie What's a Dremel?
    2 Nov 2001
    Hi,
    I want to move a huge amount of data (e.g 25 mb to 50 mb) from one remote server to another remote server.And i don't have telnet access.
    Moreover i don't want to stay connected all the time.
    Does anybody know a tool that can be useful to me ??
    Any help in this regard would be sincerly appreciated..
    Eagerly awaiting any response
    Thanks/Regards
    Great Techno.
  2. Fly
    Fly inter arma silent leges
    31 Aug 2001
    I know this is probably an important issue to you but crossposting in three different Forums on the same board (especially one this size) is not really necessary. I think the one in Networking and Communication should suffice.
    Welcome to the Forums BTW.
    Fly
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    flashfxp .... it allows you to transfer files between two ftps
  4. RTT
    RTT #parp
    12 Mar 2001
    (deleted other thread)
  5. merryfi
    merryfi What's a Dremel?
    5 Nov 2001
    Hi,
    I happened to come across a site
    http://www.ftpy-ah.com
    this site may not be perfect but it does serve the purpose of transfer of data from one server to another. And it is unbelieveably fast.
    The main problem with the site is that it does not allow you to access your local Hard Disk.
    Regards,
    Merryfi
  6. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    welcome to the forums! :)
  7. nwilcox
    nwilcox What's a Dremel?
    10 Nov 2001
    A good prog for file transfer is 'Remote Administrator' it can be found at www.radmin.com and theres a free demo if you only need to to use it a few times.
    It is also about the best remote control software out there.
