Storage fastest possible Hdd
Discussion in 'Hardware' started by dave_c, 23 Oct 2016.
  1. dave_c
    dave_c Minimodder
    31 Jul 2009
    Im looking for a new hard drive for my PC Ive been looking at these two:
    https://www.scan.co.uk/products/500...g-mgx-3d-v-nand-read-540mb-s-write-500mb-s-97
    https://www.scan.co.uk/products/500...nd-512mb-cache-read-540mb-s-write-520mb-s-98k
    But was wondering if there was anything better out there? I going to be used as my software and windows drive. replacing my Samsung 840 256Gb SSD (which will then be used purely for my games and as a scratch disk.)
    My budget is £200 but i could probably stretch this out a little more if need be.
    Any suggestions?
    Appreciated.
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
  3. David
    7 Apr 2009
  4. dave_c
    dave_c Minimodder
    31 Jul 2009
    Im not familiar with NVMe. Appreciate you pointing it out. Curious as to why everyone isnt using these. (I've been out of the loop for a while)
  5. BeauchN
    BeauchN Modder
    5 Apr 2011
    There are a few reasons, but cost is probably the main one. A similarly sized SATA SSD is just over £100, that is the cheapest NVMe drive and it's a shade under £200. For that money you'd get a 1TB SATA SSD and have change to spare.
    Compatability is probably the second biggest factor. You need a PCIE 3 x4 M2 slot to take full advantage of the speeds on offer. If you've only got a PCIE 2 M2 slot you may as well stick with a SATA drive.
  6. dave_c
    dave_c Minimodder
    31 Jul 2009
    Good to know, Im fairly sure I have 4 PCIE 3.0 slots so i think im good. Im only using one of them for my GTX 970 so should have 3 going begging :)
  7. David
    7 Apr 2009
    He means your M.2 slot needs to be rated PCIE 3 X4 - you don't need to use your actual PCIE slots for it.
    For the record, your MSI X99S Gaming 7 motherboard does have a Gen 3 x4 M.2 slot. :thumb:
  8. dave_c
    dave_c Minimodder
    31 Jul 2009
    Ah i see. Sorry for the density. good to know. as i just ordered it.
    I seem to recall poking the M.2 slot when i first got the MB and thinking "what the **** is this?" :D
