faulty CPU temp probe
Discussion in 'Hardware' started by uwannabigmak, 27 Apr 2005.
  1. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    my CPU temperature probe seems to be malfunctioning. its reporting temps constantly around ~87 degrees with good cooling and rock solid stability. Using a temp probe I found that this was very inaccurate. Its a p4 3.0 GHz on an intel 865 mobo. Is there any way to fix this problem? its annoying to have a bad readout because I can't tell when i actually have a heat problem.
  2. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Have you tried a BIOS update? Could just be something b0rked. Otherwise, there are temp probes you can put in your CPU socket and feed to a rheobus or the like to directly monitor CPU temp.
  3. HKPolice
    HKPolice What's a Dremel?
    26 Apr 2005
    Ya, bios update and make sure the pins on the CPU are clean as well as the socket.
    Other than that.... :(
