News Faulty HD 2000-series graphics cards on the loose
Discussion in 'Article Discussion' started by Tim S, 2 Aug 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. eek
    eek CAMRA ***.
    23 Jan 2002
    :eek: I've only just ordered a HD2600 XT for delivery tomorrow! I hope mines not faulty, is there anyway of telling? Will it just not work at all?
  3. Tim S
    Tim S OG
    8 Nov 2001
    It probably won't work at all, but I can't confirm that for definite.
  4. completemadness
    completemadness What's a Dremel?
    11 May 2007
    its good to know the validation software wasnt validated <_<
  5. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    I think what Tim means is that IF it's a "faulty" card then he thinks the fault will manifest itself as the card just not working at all - it's not like it will be "only a little flakey".
    Whomever you ordered it from should probably be already aware of the issue and sort you out with a replacement (if not, let us know and we'll send The Boys around)
  6. eek
    eek CAMRA ***.
    23 Jan 2002
    well I installed it, it all seemed alright (i.e. it booted into windows). First thing I did was to try to install the drivers from the CD and it blue screened halfway through... now all it does is post and can't get to the windows loading screen!! Time to post in tech support!!
    On a side note, I ordered it through Scan, free postage Cheesecake!
  7. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
Tags: Add Tags
