Windows Favourite P2P Program? (No Warez, Out, out i say!)
Discussion in 'Software' started by puzzler_uk, 7 Dec 2004.
  1. ajack
    ajack rox
    17 Apr 2003
    Torrents (ABC) / Emule
  2. Kermet
    Kermet [custom title]
    18 Feb 2003
    Have used Azureus but switched over to ABC when I couldn't be bothered downloading and installing Java on my downloading machine. Lazy I know but now very happy with ABC.
    Only really used for Linux ISOs (currently trying as many as I can get my hands on) and TV programs I miss.
  3. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    I used to use ABC, but it was such a memory whore. After installing the new J2SE 1.5.0, Azureus runs much better with the resources.
  4. DARK1
    DARK1 What's a Dremel?
    9 Dec 2004
    BitTorrnet and Limewire
  5. webbyman
    webbyman Hax.
    7 Oct 2004
    i use what he said
    limewires realy good i think :naughty:
    and bit torrents pretty good
    however kazaa is :blah: 'past it' as i nice way of putting it
  6. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    I use BitTorrent with the Azureus client also. I'll try installing J2SE 1.5.0, because it eats a lot of resources.
  7. puzzler_uk
    puzzler_uk What's a Dremel?
    7 Sep 2003
    Surely thats a bad thing???? :rolleyes:
    Unless you mean Azureus eats resources....
    :D
    English lesson folks
    sorry.....
  8. DanMcr
    DanMcr What's a Dremel?
    27 Jul 2004
    I use Shareaza every now an then, but mainly BitTorrent with BitComet.
    Took me ages sorting BitComet out, but now i have im well impressed.
  9. Hex
    11 Jan 2002
    Look up at my post... it might make more sense.
    Azureus with J2SE 1.4.2 uses a whole lot of resources for no real reason. With J2SE 1.5.0 it doesn't hog as much RAM/CPU.
  10. Firehed
    15 Feb 2004
    Disable disk caching. I kept running out of memory with 1GB with it enabled... disabling it and it's fine. JRE still takes a lot but not as much.
    In any case, Azureus is my favorite.
  11. TekMonkey
    6 Dec 2002
    Yes, you're right. I didn't articulate that very well. :eek:
  12. |I.H|
    |I.H| What's a Dremel?
    4 Dec 2004
    BitComet and WinMX for me! :D
  13. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    i just downloaded Limewire, and i find it far better than kazaa, if any download is corrupt, while downloading it will tell you if you want to stop downloading it. Best of all its open source. Used Kazaa-lite for awhile then stuff started getting full of virus's and you werent sure of what you were getting. I also use IRC/flashfxp. Tried using bitcomet, but i really didnt like the upload/download kbps (would take a couple of hrs to download a 50-60mb file).
  14. DanMcr
    27 Jul 2004
    I thought it was crap when i got it, but at least as good as the default client. Then had a poke around on some forums and got it working really well. Upload is capped at 14kbps, and download upwards of about 70kbps. (Depending on seeds etc)
  15. fizban
    fizban What's a Dremel?
    11 Jun 2004
    bittorrent for tv shows I miss.
  16. mushky
    mushky gimme snails
    24 Mar 2003
    edonkey :worried:
    Dont think my netgear router like bit torrent. One day I will try a straight connection to the internet to find out. One day I will tidy up these drawers. One day.
  17. Ln2OC
    Ln2OC What's a Dremel?
    6 Dec 2004
    New to using Azureus ?
    Help :sigh:
  18. Hex
    11 Jan 2002
    Start a new thread in this forum detailing what's causing you problems & we'll see if we can help you :)
  19. B.Psycho8
    B.Psycho8 What's a Dremel?
    8 Aug 2004
    soulseek :D
  20. buchans
    buchans What's a Dremel?
    28 Jun 2004
    BitTorrent - Azureus@home & Torrentstorm@work
