Other Fax software
Discussion in 'Software' started by bixie_62, 8 May 2009.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    Hi all
    Just wondering if somebody could help me locate/find some sort of fax software which is simple to use
    basically, dad has a small engineering firm manufacturing bar turned parts, nuts etc, and they tend to use the fax a lot, and as such, they've been using the same old ribbon style one for aages
    I was wondering if someone knew of some way to receive the fax on a computer, print those that require printing, or to just somehow write directly onto the fax (such as using a textbox of some sort) and to fax it directly back without printing it.
    Does anyone know of any such software?
    cheers
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    We use Zetafax at work, I'm not sure if it will be too fancy or expensive for small use.
    www.equisys.com
  3. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    Hi there
    we tend to receive around 100 faxes between 10am and 5pm, and sending usually around half of that
    it would be great if the software had some sort of 'scan in' feature as we send the bacs sheet to the bank via fax
    I should mention we have an epson cx-11nf and a brother mfc-7420 at our disposal
    i just cant for the life of me figure out how to set this all up!
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    By comparision my office sends about 100-200 faxes an hour and recieves about twice that.
    We do have a large setup from Zetafax, but some of their products are for smaller businesses.
  5. barack
    barack What's a Dremel?
    11 May 2009
    definitely zetafax is what i recommend.
