The request from the sponsors has brought nothing. Now the cooling for the Sapphire motherboard will be rebuilt.
Da hatte ich selbst probleme das zu lesen mann muss sich nur in den accent reinsetzen This is also a very nice build I'll be watching the rest. And for the Youtube vids, why not use the
This I could find no FM1 board I now had to rebuild the cooling for a AM3 socket. So, first remove the heatpipes I had lying around here a beautiful spring. But, unfortunately, was too rigid, thus I have not broken one of the heatpipes. I then converted a Coolermaster cooler I've cut all the plates and removed. Then it was time to turn ... this was the purest trembling partie I then got a little spring time and it broke at the line tested. I did not think it works so well, even though the spring is so fine. the holder has been cut Then it was off to the first page, but it was a grind, the pipes stand out quite nicely... ...the second one was taken to the large bending spring to have a better handle. To fix in the cooler times I only have to rebuild the retaining clip, as the pipes were a little in the way. From built-in condition I have no picture. Make but the days when I install a new Ram. During assembly, I noticed that interferes with the bracket for the 3.5 "HDD, than get rid of it The 2.5 "HDD I then also decoupled. In addition I have the rubber of the 3.5" plate is used. So it looks after assembly. Unfortunately not you go otherwise, since it is almost press fit So, that's it then was with updates. That's a picture of the CPU socket is more, and then once the final pics.
