CPU Feedback: Intel i5-760 or 750?
Discussion in 'Hardware' started by Snubbs, 10 Aug 2010.
  1. Snubbs
    Snubbs CustomPC Migration victim....
    27 Mar 2009
    Hi,
    I'm going to be getting an i5 rig very soon. However, with the i5 750 and 760 only been £6 appart, I'm unsure which CPU to go for.
    With the 760 been lynnfield based, will be overclock better or worse than 750?
    Cheers, James
    --edit--
    oops - I read somewhere the 750 was clarkdale based (wrong) :p even so -760 better or worse?
    Cheers
    --FEEDBACK--
    Thought I would feedback to this post - I bit the bullet and grabbed the 760.
    I haven't been able to fully stress-test, as I'm currently concentrating on getting the most out of my RAM, but it seems quite stable after a rather modest effort of overclocking:
    With the following settings in my MSI P55-GD65
    VDroop - High
    CPU Voltage - 1.351
    CPU VTT - 1.298
    CPU PLL - 1.860
    PCH 1.05(V) - 1.059V
    Baseclock 200mhz
    Multi - x21
    4200mhz i5 :p
    As I say, I've yet to fully stress test, so it could fail - however I have no doubt that with a little extra voltage, it'll either be 100% stable or overclock further (4.5 anyone?) I'm still getting used to the i5 limits and the way the motherboards work (as I've been SKT775 for the last 5 years or so :p)
    Anyways, thanks for everyones input. As for the last poster (regarding ebay) - personally I'm not a massive fan of buying computer kit second-hand, I know that I look after my kit, however you can never be sure whats happened to someone elses.
    However, many individuals do get a great bargain by taking a risk, however at the moment, I prefer the assurance I get from buying from Scan.co.uk (I know some people have bad experiences, but they've only ever been good with me).
    Cheers, James
    P.S. I'll try and update this thread again once I know everything is stable :rock:
  2. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Better. But really, at £6 do you care??
  3. Snubbs
    27 Mar 2009
    It's more that I don't want to buy the 760 to find out it won't get as high as the 750 - I know logic says it should go higher, but we all know what CPUs are like :p
    Think I'm going to give it a go then - unless the 750 is in scans today-only today, I'll be ordering the 760 (I've seen some have got it to 4.2 on air).
    Cheers, James
  4. Pete J
    Pete J Employed scum
    28 Sep 2009
    760 without a shadow of a doubt. Hell, I'd buy it if it were £20 more, let alone £6.
  5. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Really? You'd actually pay £20 just to have the extra multiplier? Because that's the only difference between them...
    With a half decent board both of them should be able to hit 4GHz without too much trouble, which is about the best you can hope for from a mid-range CPU. As it is, it's only a few quid difference so you might as well go for the 760. If it was any more I'd just say go for the 750, as the 860 and 930 would start to look more attractive.
  6. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    I can't speak about the 760 but for the price difference you might as well go for it. I can say that my 750 will go past 4 gig, with a gigabyte motherboard, without a problem but I need a better cooler to be sure how far I can safely push it.
  7. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    You looking on Scan?
    The 760 was on for £140 last week, £6 less than the 750.
    Back to normal now which is a shame, but yes. Definitely the 760 for the price difference.
  8. Ljs
    Ljs Modder
    4 Sep 2009
    760 is £146.86 on Aria FYI.
  9. Pete J
    28 Sep 2009
    Yup.
  10. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    So, would you sell your old 920 D0 off and bump up to a 930 if it only set up back another £40 or so? :p
  11. okenobi
    3 Nov 2009
    Me too.
  12. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Wow. I guess I really struggle to see the value in that.
    I suppose if you were a hardcore overclocker with a decent watercooling setup/LN2 pot you might be able to eke a few more MHz out of it, but then you wouldn't even be choosing from a 750 and a 760 anyway, you'd be buying something much more high-end.
    But in the real world, for your average user, the difference would be a big fat 0.
  13. gliese581d
    gliese581d What's a Dremel?
    10 Aug 2010
    No brainer!!
    Fella this really is a no brainer!!
  14. okenobi
    3 Nov 2009
    In terms of overclocking, even on air the difference of one multiplier (especially to an odd multiplier) seems to have made quite a bit of difference in the top end. So for £20 it's worth doing for longevity IMO.
  15. Snubbs
    27 Mar 2009
    Hmmmm the 750 is on for £140 today only, however I imagine the 760 will follow suit again - Scan seem to have a habit of continually putting the same components in "today only" week after week.
    I need the CPU most likely for Monday at the latest - so I'll wait until Thurs/Friday and see what comes up.
  16. Snubbs
    27 Mar 2009
  17. Pete J
    28 Sep 2009
    Probably! My 920 only runs at 4GHz thanks to my mobo forcing a 21x multiplier the whole time - on a lesser board I'd be stuck with 3.8GHz.
    For me it'd make a difference as the extra RAM I have limits the BCLK - hence an additional multiplier would add a nice ~200MHz.
    But anyhoo, it'd be madness to buy the 750 now that the 760 is out - unless the 750 suddenly plummets in price...
  18. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
    Got an i5 750 for £80 on ebay last month. Why pay full price for something that'll be outdated in a year(or maybe less).
    Just got to be carefull who you buy off.
  19. Snubbs
    27 Mar 2009
    Updated my first post
