Build Advice Feedback on gaming build.
Discussion in 'Hardware' started by FZRaven, 17 Feb 2012.
  1. FZRaven
    FZRaven What's a Dremel?
    17 Feb 2012
    So it's been a few year since I've built a rig. The last rig I built was a P4 2.8Ghz with a ATI 9700 Pro, so ya it's been a bit.
    Budget:
    Right around $1500
    Main uses of intended build:
    Gaming, Internet, some photo editing.
    Parts required:
    CPU-Intel Core i5-2500K
    Cooler-COOLER MASTER Hyper 212 Plus
    Mobo-ASRock Z68 Extreme3 Gen3 LGA 1155
    Ram-G.SKILL Sniper Series 8GB 1600
    HDD-Seagate Barracuda ST2000DM001 2TB 7200 RPM SATA 6.0Gb/s
    SSD-Crucial M4 CT064M4SSD2 2.5" 64GB SATA III
    Graphics-SAPPHIRE Radeon HD 7950 3GB
    Case-COOLER MASTER Storm Scout
    PSU-SeaSonic M12II 620 Bronze 620W
    Monitor resolution:
    1920x1080
    will you be overclocking: yes, looking to overclock to around 4.6Ghz
    Extra information about desired system:
    I'm looking to build a gaming machine primary, but I also watch a lot of movies and TV shows on my computer and a little photo editing also. I'm not looking to have massive amounts of HDD space as I'm intending to build a NAS system when HDD prices come back down the rest of the way.
    I'm just trying to make sure what i've put together here is good, maybe some things I should change.
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Nice build :thumb: I'd say swap the SATAIII HDD to a SATAII to save some money as you won't see a performance benefit. And I'm not too fond of ASRock boards, I prefer ASUS or Gigabyte but obviously it depends on budget and your own personal experiences really.
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Not too sure if the Hyper 212+ will be happy at 4.6~ Ghz. Might have to grab something beefier. I highly reccomend anything from BeQuiet! or the monolithic Thermalright Archon if you've got the space. Both of them make nary a whisper if they have to spin up, and can cool very well in most scenarios.
  4. Shirty
    18 Apr 1982
    +1 to .//TuNdRa's point about the cooler. Any particular reason why you are choosing to use a two and a half year old model? Not that there is anything intrinsically wrong with it, but you will get much better cooling performance from a more modern model such as the Dark Rock Advanced or the Thermaltake Frio. I personally use the Frio in an Antec P182 and I am rock solid at 4.8 on my 2500k, never exceed 55 degrees :hip:
    ASRock boards are generally pretty decent for the mid-range user, and I have seen reports of overclocks around the 4.6 to 4.7 mark for your chosen board. Pretty good for a budget offering.
    I haven't used one since I was using an Athlon 2400+, but it did what I wanted it to back in those days.
  5. FZRaven
    17 Feb 2012
    Thanks for the suggestions, i'll look into that. Maybe if I save a little on the HDD it will be enough to cover a better CPU Cooler that the other poster recommended.
  6. FZRaven
    17 Feb 2012
    Trying to be cheap really, I'm going to look into saving some cash on the HDD as the other poster suggested and put that into a better cooler.
