Cooling Female to Female fan lead.
Discussion in 'Hardware' started by Spanky, 17 Mar 2016.
  1. Spanky
    Spanky Minimodder
    14 Apr 2010
    Guys.
    Im trying to find a female to female PWM 4 pin cable and I cannot seem to find one. I need it for a multi PWM header but dont have any way to connect to the motherboard ... as both male connections.
    Any ideas please??
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    If you get stuck you could buy two female to male cables, send them to me and I'll cut, solder splice them together, heatshrink and then sleeve the resulting cable with paracord for you. (only have black or purple paracord at the moment, I may, just may have some blue though)
    Just cover the postage
    PocketDemon likes this.
  3. Reg216uk
    Reg216uk Minimodder
    2 Nov 2011
  4. Spanky
    Spanky Minimodder
    14 Apr 2010
    Cheers Crapbag :thumb:. Very good of you to offer. But Moddiy.com has sorted it for a decent price.
    Happy days.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    $9.95 delivery charge on top mind.
  6. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    Yeah, without rubbishing CrapBag's kind offer to you, tbh it would be much the same cost to buy a complete 4 pin PWM fan splitter in the UK - & obviously a bit quicker on the delivery front than from Hong Kong.
    Without stating that this is the best price currently for the thing, http://www.ebay.co.uk/itm/Phobya-PWM-8-x-4Pin-Fan-Splitter-/231850805590 is what i use, & had no issues with the seller ordering a couple of times from them.
    Along with the splitter itself, you also get a female molex + 4pin (2pin electrical) female fan -to- 4 pin female fan cable - which ensures that you're not attempting to pull too much power from the on board fan header.
  7. wolfticket
    19 Apr 2008
    I'm not really an electronics guy, but circuit wise, would a 2 way splitter cable with the two female "outputs" used and the male input left empty work at a push?*
    *may destroy your computer, burn house down, kill beloved pet etc. :)
