Cooling Fenrir or Thermalright Ultra eXtreme 120?
Discussion in 'Hardware' started by Pookeyhead, 5 May 2009.
  1. Pookeyhead
    30 Jan 2004
    Which one?
    Thermalright Ultra eXtreme 120 is a nice piece of kit, but the results of the Titan Fenrir are similar, and it's only £33.
    It seems a no brainer...
    Am I missing something?
  2. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    I've been looking into this myself, when the Fenrir is pwm controlled it performs well, but is still a few degrees higher than the Ultra 120. The Titan fans runs at a max of 2200 rpm, whereas the Ultra 120 fan runs at a max of 1600rpm, hence why the Fenrir does so well at its high speed fan setting.
    So if you were to put a similarly high rpm fan on the Ultra, it should perform much higher than the Titan. If you want the absolute best cooling, the Ultra still wins, but for £20 quid less the Fenrir is a good choice, if noisier at high speed. And the Ultra 120 gives you the option of selecting your own choice of fan, the 1600 rpm one I mentioned is the Thermalright part.
    A review of the Fenrir
    http://www.frostytech.com/articleview.cfm?articleid=2383&page=1
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I have the tr120extreme.. yeah turbo is right.. you stick a decent fan on it and it does it's job.. I'm no fanboy but I do own it- it's a nice heatsink..
    33 sounds good.. but I always look at it like this- how can you really match the freezer 7 in price/performance- it goes for 20 around here
  4. Guest-16
    Guest-16 Guest
    Pff Freezer 7? They are in different leagues. Even the Akasa 965 is better than the Freezer 7 and that can be had for just over £11.
  5. thehippoz
    19 Dec 2008
    really? well not that cheap here- in the us sometimes you can get the freezer open box on newegg for 10 bucks.. but not too often
    the freezer wasn't too shabby when I owned it, I lapped it though- haven't tried the akasa.. looks like runs about 25 here.. I'll remember that though- how much better than the freezer?
    * oh nm you meant the fenrir.. well yeah of course! =]
  6. Pookeyhead
    30 Jan 2004
    Bindi....
    What would you do? You can work out what this new rig cost me, so I'm not going to balk at spending an extra £20 or so, but the review of the swiftek water cooling system you recently did compares it to air set-ups, and in that review the Fenrir beats the 120.
    IS that purely down to fan speed? Would fitting a 2k rpm fan to the 120 make that much difference?
    I just want the best cooler, regardless. I'm not ready for water cooling yet, as there will be too much downtime, and this is the only PC I have at the moment. Water will come later... although knowing me, by that time there'll be something else to upgrade to as well :)
  7. Guest-16
    Guest-16 Guest
    I've no idea tbh, I shall have to ask CustomPC or steal the Fenris to use for myself if I know where they put it.
  8. Pookeyhead
    30 Jan 2004
    I'd love to see the 120 with a 2K fan up against the Fenrir. Instinct tells me that should be the way forward.... but.... the noise.. LOL. Jet-tastic!
  9. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    i'd go noctua myself but isn't the core contact freezer high on the price/performance arena
  10. thehippoz
    19 Dec 2008
  11. Turbotab
    4 Feb 2009
    If money is not an issue then the Ultra 120 has an advantage, you can run it with 2 fans in a push / pull configuration. Bjorn3d tested the Ultra in this dual fan config, and it ran 2 degrees cooler than the Fenrir, overclocked and at load.
    http://www.bjorn3d.com/read.php?cID=1552&pageID=6769
    In an another test, adding a higher 2000 rpm to the Ultra improved its performance by 2.6%, thus you could use 2 high rpm parts, to additionally boost performance.
    http://www.hardwarecanucks.com/foru...ra-120-extreme-1366-rt-cpu-cooler-review.html
  12. Slaymate
    Slaymate bit-tech Slayer
    15 Feb 2009
    I don't know if it's available on your side of the pond but I would be considering the Prolimatech Megahalems.
    http://www.prolimatech.com/index.html
    As for your 2 choices I would go for the Thermalright, but they work best after lapping the base flat.
