Graphics Fermi High End Owners Club (ATi enter @ Risk)
Discussion in 'Hardware' started by AoE, 30 Jan 2012.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    I dont understand what kind of software issues?
  2. Guest-44432
    Guest-44432 Guest
    This.
  3. jizwizard
    jizwizard Modder
    24 Dec 2010
    stock 797/1950 overclocked 900/2000
    running a single 570
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    That's one heck of a bump on Minimum FPS.
  5. jizwizard
    jizwizard Modder
    24 Dec 2010
    theres a bug the first time you run it that drops the fps at the start it would normally be around the 20fps on start up on standard clocks. couldnt be arsed to run it twice at standard
  6. .//TuNdRa
    12 Feb 2011
    I thought the trick for that was just to let it purr through outside of the Benchmark for a minute, then start it?
  7. Guest-44432
    Guest-44432 Guest
    This is what I have been saying about this benchmark. As due to the power saving features on Modern GPU's, the very first second you run the benchmark, yours clock speeds take a second to get up to 3D clocks.
    What they need to do is, start the benching about 3 seconds into the starting process, so your clock are at 3D clock speeds, before the benching beings. Otherwise, it is pot luck trying to get it to give you higher min FPS.
  8. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Doesn't always work.
  9. dead beat
    15 Feb 2009
    Yeh but there's also the issue about two thirds of the way through the bench, where it pauses for a split second in the dark stone tunnel. That's the bit that's always hit or miss for me.
  10. AoE
    4 Oct 2011
    anybody any idea what software issues are holding me back? im skeptical its a cpu issue
  11. Guest-44432
    Guest-44432 Guest
    Well, when you look at my scores, at the same setting as yours and I set the GPU clocks to yours. Doesn't that show/tell you something?
  12. AoE
    4 Oct 2011
    wish there was someone here with a 580 and phenom 4ghz
  13. dead beat
    15 Feb 2009
    I used to have a 955BE @ 4Ghz. When I switched to the 2600k, everything became much quicker. It's almost certainly your cpu.
  14. Guest-44432
    Guest-44432 Guest
    Yes, and I have also mentioned this several times. Vram is only at 737MB max throughout the whole benchmark, so its not a vram limitation.
    You will notice that the GPU usage drops from 99% to about 5% on all GPU's in that area. So there is a bug in the benchmark.
  15. dead beat
    15 Feb 2009
    Doesn't look like they have any intention of fixing it.
  16. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Can I just say, I am in this club but the 460 club is better cos only cool people own 460s. I'm not cool anymore :(
  17. Fuzzy
    Fuzzy What's a Dremel?
    1 Feb 2012
    AoE, your Heaven bench jpg shows you ran it in 8xAA, we all ran it at 4xAA - check that first before you go worrying about hardware or software problems.
    Run in in 4xAA and repost your results.
  18. .//TuNdRa
    12 Feb 2011
    And hipsters own 550s? Balls.
  19. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    @ 900Mhz core clock, and stock volts :D
  20. N17 dizzi
    23 Mar 2011
    nah 550 owners are pretty cool too, hipsters... hmm I'd say 6950 owners that have the 6970 bios?
    ooops, mentioned ATI in the Fermi thread....
