Graphics Fermi High End Owners Club (ATi enter @ Risk)
Discussion in 'Hardware' started by AoE, 30 Jan 2012.
  1. Fuzzy
    Fuzzy What's a Dremel?
    1 Feb 2012
    What happened to 4xAA and 16AF? :)
  2. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    GET OUT :D
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Oh phew. I can chill then. Although I can barely scrape 570 horsepower out of these, so there's no way on earth I can join this club with these cards.
  4. Pookeyhead
    30 Jan 2004
    That extra VRAM makes a hell of a difference.
    Here's mine (2x SLI) at 865.
    and for the purposes of scaling... 1x 580.
  5. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    I'm surprised to see the 570 do so well; it's very close to the 580, much more so than the 480 is.
    Loving this thread - very informative. :thumb:
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Really? I must admit that in most situations SLI Gigabyte 460 oc comprehensively beats a single 580 in almost everything I have tried apart from games that need more V ram...
    That is with clocking the nuts off both setups.
    2 x 580 will be a different matter *licking my lips* :rock:
  7. thetrashcanman
    18 Nov 2010
    You think? I wouldn't have thought it would have made that much of a difference at 1920 x 1080, in a minute I'll try running at your clocks so we can compare :)
  8. wyx087
    15 Aug 2007
    580 users doesn't seem motivated to overclock, compared to other card users. come on!
    everything stock, CPU and GPU, RAM at loose 1333MHz 9-9-9-[can't remember]:
    very interesting min-FPS doesn't affect the score, in comparison to Pooky. but min-FPS does seem to be relying on CPU as well as GPU.
    CPU/RAM not changed, overclocked at 925/2100, high-ish overclock that i know will work first go:
    i usually keep system at stock, since don't see point of having OMGHz frequency in every day use sacrificing energy efficiency. hence the relaxed RAM and CPU speed, didn't bother to boot into my zOMG profile.
  9. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    2 x 580's @ 950mhz
    3 x 580's @ 950mhz
  10. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Huh. Strange that your min FPS goes down with the 3rd 580, but max and avg go up...
  11. dead beat
    15 Feb 2009
    Yeah, I put that down to Heaven glitching.
  12. thetrashcanman
    18 Nov 2010
    For Referance Pookey [​IMG]
    appears the extra vram does make a difference, temps never went above 25 C :D I love watercooling
    and at my max overclock 1.075Ghz
  13. .//TuNdRa
    12 Feb 2011
    In Non-antialiasing tests; these can boss a typical 570, but when AA kicks in; they start to fall behind.
    I used a friend's 570 Phantom for a comparison point, so It's not a slow setup, but it's a touch slower than I'd like.
  14. N17 dizzi
    23 Mar 2011
    I just had a Crysis hour run @ 925 Mhz 1150 mv with high fan speed, 74c max, 70 c settled. Very impressed.
    2 of these is gonna be a beast, can't wait
  15. Undead.Potato
    Undead.Potato What's a Dremel?
    10 May 2011
    My 570 Phantom With a Clock Of 920/1800/2250 @1.125v :thumb:
    Love This Thing.:rock::rock:
  16. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    That's all the settings maxed in Afterburner. Looks like I'll have to flash the BIOS ro achieve higher clocks. Oh and that score is exactly the same with my CPU at stock as it is with it 3.8GHz.
    Edit: Oddly that's only 1 point more than I got with the GPU at 825/1650/1900 :confused:
    LennyRhys likes this.
  17. Pookeyhead
    30 Jan 2004
    Here is dead beat's
    What gives? I assumed the 3GB cards were just better, but these seems to be 1.5GB cards too. I'm baffled. I know his are at 950, but....
    @dead beat. Can you run that again at 865/1730 clock/shader with vram at 2103?
  18. N17 dizzi
    23 Mar 2011
    Can people post the voltages they are using for 920+ core on a 580... I have got 925 stable but would be interesting to see what others are doing voltage wise (including those that are watering :) )
  19. wyx087
    15 Aug 2007
    maximum voltage Afterbuner allows, with maximum fan speed. after all, overclocking is only good for benchmarking so just go for it.
    no point overclocking for every-day usage IMHO.
  20. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    @ Pookey, dead beat is using the most recent beta driver which could explain the extra performance. I'm going to install it now and see what difference it makes.
    One oversight in these comparisons is that the 580 users all have different drivers installed
    285.62 (WHQL)
    290.36 beta
    290.53 beta
    295.51 beta
    Perhaps if people could state what driver they are using when they post screens and that will make the comparisons easier. :thumb:
