Scratch Build – In Progress Ferrari Enzo tribute - 20/12/2007 - *ON HOLD*
Discussion in 'Project Logs' started by ssR, 12 Mar 2007.
  1. Mr. Oizo
    Mr. Oizo That yellow furry animal-thingy
    18 Mar 2007
    I'd go for the GT40 ofcourse! Thats the most beautiful car ever! (Yes, even cooler then the Enzo:p)
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    the gt40 is a nice car, but the enzo is sexier, not to mention F40, F430, F50, testarossa.... mmmmm i like ferrari :)
    i think the gt40 stripes will be great however! they are racing stripes, so they will match the theme of a ferrrari pc. the other thing is that two white stripes over the top and 2 along the base of each side will make the case seem longer & thinner. the same way that vertical stripes make people look skinnier & taller, and horizontal ones make people seem shorter & wider. racing stripes look cool aswell, go for it!
  3. NightCrawler™
    NightCrawler™ What's a Dremel?
    11 May 2006
    The Ferrari Enzo FXX has a white stripe.... :D
  4. ssR
    ssR Carbon God
    11 Aug 2006
    Thanks for the ideas guys, I'll let you know when I'm locked on a certain painting scheme and thanks NightCrawler, I will definitely consider the FXX scheme :D
    Meanwhile here is another update for you. I decided to cut the case open today and although the work is not done yet i still made some progress i can share. My original plan was to use a dremel diamond cutting disk but we didn't have any in stock at work so i began working my way with an exacto saw. I opened up the side air intake areas and i still have to cut the "doors" which i couldn't do today since the saw simply couldn't reach there. So instead i decided to open the rear mobo tray cover.
    Cutting the front side intake using an exacto saw
    Marking and masking the rear mobo tray cover
    And its open
    I cut off some of the foam to glue the side supports that will preserve the cover shape
    And after gluing it in place
    Next stage was to dissolve the foam using thinner
    And the cleaned up cover
    Test fit back in place
    Hopefully tomorrow we will get the diamond disks so i can complete the cutting phase. In case we don't, I will probably get some more bodywork done and get the rear cover finished (still have some reinforcements to do
  5. harvy
    harvy Minimodder
    12 Apr 2006
    Sweet case! Keep up the good work!
  6. wbdog206
    wbdog206 not me
    15 Jan 2007
    nice glass work,looks good
  7. ssR
    ssR Carbon God
    11 Aug 2006
    Thanks guys :)
    Sorry only had about 1 hour of work done today, got a busy evening ahead of me. I got the Diamond cutting disk i wanted and so I could finish cutting the case open. Here are some pics (this time higher quality as i got my hands on our camera today 8) )
    The next phase will be probably the custom made hinges for the top and more reinforcing and bodywork
  8. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    I like where you're heading with this ssR :)
    I have to admit when I seen the first sketchups I was a bit dubious but as soon as those curvy vents came along I knew you were onto a winner! My apologies for the initial lack of faith ;)
    Being a kind soul who loves Ferraris I thought I’d give my 2 cents on the go-faster stripes:
    There is a motif Ferrari use on their challenge stradale cars, a white stripe with a simple Italian flag style pinstripe, you may like it, you may not but I thought I’d throw it into the pot anyway!
    Best of luck, can't wait to see the finished result, the machines gunna be rapid!
    Well... everyone knows red computers go faster?
  9. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I can't say it enuf, kick ass work ssR! :rock:
  10. ComputerKing
    8 Sep 2006
    this is the cooolest case I ever saw!!! man this is amazing... enzo style.. Dam I love it.. I want it :D good luck
  11. KaotiK
    KaotiK What's a Dremel?
    2 Jul 2007
    looking good man. keep it up
  12. ssR
    ssR Carbon God
    11 Aug 2006
    Thanks everyone, your support over here is much appreciated!
    Vo0Ds: actually another members suggested the exact same theme over at TMN forums, but i think if i eventually decide to go with the racing stripes, i will go for the more classic look of 2 wide white stripes on top of the case. Still thanks for the suggestion :)
  13. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    This is looking really good! Have been following from the beginning, and I must say that this is excellent work! ;)
  14. ssR
    ssR Carbon God
    11 Aug 2006
    Thanks again :)
    Some more progress for today. Started carving the foam out of the side intakes. This will be done in several stages.
    First i will be taking out about 3-4cm of the material and reinforce the walls of the intakes with some more carbon. Then once the structure is solid enough i will carve out the remaining foam and cut the intakes open.
    I also carved out about 1cm of foam from the bottom and will be putting a sheet of rohacell to give additional support to the structure. When i'm nearly done the whole bottom will be covered with another single piece of fiberglass to seal it.
    I also worked on the rear panel cover, reinforcing it with some rohacell strips and some carbon layers
    The rear cover with some additional rohacell strips, ready for the carbon reinforcement
    After the first layer
    After another carbon layer and finally a thin fiberglass layer to seal the deal (i dont want any bare carbon in this pc, might be dangerous for the components)
    Finally after a peelply layer
  15. Mr. Oizo
    18 Mar 2007
    Looking good! Keep up the (very) good work! :)
  16. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    nice to see this mod rapidly progressing. the way you work with that carbon i cant wait to see your skillz with that paint :D
  17. ssR
    ssR Carbon God
    11 Aug 2006
    Thanks again :)
    elbarto241: there is a long way to go till i finally paint the case :). Be patient
    Here is an update for today.
    Marking the cutout on the rear cover
    And cutting
    After some trimming and sanding
    I decided to go with the standard hinges for the top section after all. Some adjustments will be made to reinforce this area, so it can hold the upper section weight
    Carbon reinforcements on the side air intakes
    Some more carbon on the rear cover
  18. Frido
    Frido Minimodder
    19 Apr 2007
    Amazing! Fabulous CF work! Such detail, super workmanship.. Wish I had the same l337 skillz as you!!!!
    I'm looking forward to see everything plugged in and running. About the racing stripes, I'd go GT style :)
    Totally f***cking subscribed!
    /Frido
  19. ComputerKing
    8 Sep 2006
    man that is very pro work!! well done and good luck take care and keep going :clap:
  20. ssR
    ssR Carbon God
    11 Aug 2006
    Yet again, thanks for your feedback :)
    I have another update for you guys. Now that the case is open, I can finally begin working on the interiors. Here is the progress for today:
    Making the sliding rails for the mobo tray
    Making the PSU mounts. I used 2 pieces of glass epoxy. After cutting it with a diamond cutting wheel and some drilling and final sanding this is what came out
    I also trimmed and sanded down the carbon reinforcements on the side air intakes
    The next step was to begin making the mobo cover. I used some sheets of MDF to make the basic square shape and then sanded it down and rounded the corners to allow the fiberglass take it all in one piece. Finally with the basic shape ready i covered it with a teflon tape )faster and better way than using mold release wax, as nothing sticks to teflon
    Laying down the first fiberglass layer
    After 3 layers of fiberglass and a peelply layer
    This is what I'm aiming for :)
