Case Mod - Complete ⭐ FERRARI PROJECT CMWS 2019
Discussion in 'Project Logs' started by Sa mod pc design, 28 Jul 2019.
  1. Sa mod pc design
    Sa mod pc design Member
    7 May 2019
    Ciao a tutti,
    Ti mostrerò il mio progetto. È un omaggio alla Ferrari e userò la pelle per coprirla.
    Specifiche:
    Alimentatore Cooler Master V1200 platino
    Master di raffreddamento Cosmos c700p
    Masterfan mf120r Cooler Master x8
    Asus strix x470
    Ram Dragonheart S3 + 4x8 2666 mhz
    ssd m2 512 gb S3 +
    Alphacool watercooling
    Amd Ryzen 5 3600
    Gpu Asus strix 2080 super
    TodMod likes this.
  2. TodMod
    TodMod Active Member
    14 Dec 2018
    love it!!!!!
    congratulations!!!!!!
    Sa mod pc design likes this.
  3. Sa mod pc design
    7 May 2019
    [QUOTE = "TodMod, post: 4684655, membro: 872729"] lo adoro !!!!!
    complimenti !!!!!! [/ QUOTE]
    Thanks tod
    TodMod likes this.
  4. douglas alves
    douglas alves Active Member
    3 Mar 2014
    Very good.
    Congratulations
    Sa mod pc design and TodMod like this.
  5. Sa mod pc design
    7 May 2019
    Thanks douglas:)
    douglas alves likes this.
  6. Cheapskate
    13 May 2007
    I should have suspected there would be leather when I saw you were in a purse maker's shop. Lovely work. I'm guessing you have a really beefy sewing machine too.
  7. Sa mod pc design
    7 May 2019
    I use a triple transport... I hope you like the job
  8. Yury
    Yury Member
    7 Mar 2019
    Fine work, Congratulations
  9. Sa mod pc design
    7 May 2019
    Massive thanks to Coolermaster Italia, Asus Rog Italia, Alphacool, Touchthegame, Gszcustom, S3 Plus Technologies, Italian extreme modders.
  10. Sa mod pc design
    7 May 2019
    Let's start to work.
    I started to disassemble cosmos c700p.
    After I painted chassis.
  11. Sa mod pc design
    7 May 2019
    Now I started to work on the front panel.
    First I created paper template.
    After I prepared another paper template for stitchings.
  12. Sa mod pc design
    7 May 2019
    Now I glued leather on the front panel and I trimmed the edges.
    I did also a test for the badge.
  13. Sa mod pc design
    7 May 2019
    Now I created top panel's paper template.
    I cut the leather.
    I glued the leather on the top panel and I trimmed the edges.
  14. Sa mod pc design
    7 May 2019
    Now I started to work on front panel's internal part and I created paper template.
    I cut the leather and I did the stitchings.
    I glued the leather and I trimmed the edges.
  15. Sa mod pc design
    7 May 2019
    Now I started to work on the back panel and first, as usually, I created paper template.
  16. Sa mod pc design
    7 May 2019
    I started to work on the side panel and first I created paper template.
    Now I cut the leather and I did the stitchings.
  17. Sa mod pc design
    7 May 2019
    Now I created cover psu in plexiglass.
    After I created paper template and I added a thick.
    I cut the leather, I did the stitchings and I glued the leather.
    I added particular details of leather.
    I attached a laser plexiglass writing.
  18. Sa mod pc design
    7 May 2019
    Now I started to work on the internal panel.
    I assembled motherboard Asus x470 strix, cpu and gpu waterblock Alphacool, ssd S3+ and ram S3+.
  19. Sa mod pc design
    7 May 2019
    Now I created paper template and I cut plexiglass.
    I did holes for cables and I started to bend tubes, I took measurements to do holes for passthroug and I did them.
    I finished to prepare tubes of the front part and I fixed reservoir.
    At this point, I did also the back tubes.
  20. Sa mod pc design
    7 May 2019
    Now I disassembled and I started to apply the leather on the panel.
    I did details for holes.
    This is the finished work of pc interior design.
    I created also a little panel to cover cables .
