Cooling few questions...
Discussion in 'Hardware' started by George, 22 Jul 2002.
  1. George
    George Bah
    14 May 2002
    im getting a variable enermax 120mm fan, and a fan fixing kit, how do i mount the fan 1" away from the rad (OCPC 'The Deep').
    will the fan fixing kit even work with the RAD, if not, how the hell do i mount the fan?
    what liquid solution should i use?
    i dont really want waterwetter or purple foam stuff, is there any stuff i can get from the esso garage down the road? :D
    distilled water and something, right?
    thanks.
    .icecube
  2. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    rip the fan bit out of an old 120mm and use the round outside bit between the enermax and the rad.
    i use 5% antifreeze in de-ionised water.
  3. George
    George Bah
    14 May 2002
    that could be a problem, i dont have any other 120mm fans...
    .icecube
  4. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    I used washers(the kind used in sinks) to space my radiator and fan, works pretty good. I've always been a water wetter man meself...you should get a bottle(some car shops have them) and some distilled water(from a pharmacy). Let us know how it goes :)
  5. George
    George Bah
    14 May 2002
    btw, is there holes in the OCPC rad for a fan to be mounted?
    looks like ill have to buy a cheap 120mm fan too then...
    .icecube
  6. George
    George Bah
    14 May 2002
    just how important is it for the fan to be mounted 1" away from the RAD, as i dont want to spend £10 on a 120mm fan just to take the frame of it...
    .icecube
  7. Lucifer
    18 Nov 2001
    surely someone has one spare?
    infact i do.... lol
    mail me your address and i'll see if i can post it to you tomorrow
  8. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Well the problem with fans is that theres a "dead" spot in the middle. Spacing it 1" from the fan will give you better flow through the radiator. You don't have to do it, but its for the better IMO.
  9. George
    George Bah
    14 May 2002
    you want any cash for it?
    .icecube
  10. Lucifer
    18 Nov 2001
    prolly not worth it, after nochex or wotever. i assume you are UK based btw?
  11. George
    George Bah
    14 May 2002
    email address to send my details, and thanks alot for this man.
    also, how should this be mounted to the RAD, will a nut and bolt do the trick with the OCPC, as im getting a fan fixing kit from overclockedpc.co.uk.
    .icecube
  12. Lucifer
    18 Nov 2001
    not tried the OCPC rads but i use zip ties.
  13. George
    George Bah
    14 May 2002
    where can i get zip ties, lol.
    .icecube
  14. George
    George Bah
    14 May 2002
    from a hardware store, right?
    .icecube
  15. Lucifer
    18 Nov 2001
    yea
    mail now in sig btw, i don't have your email address
  16. George
    George Bah
    14 May 2002
    you got my mail yet?
    .icecube
  17. Lucifer
    18 Nov 2001
    yea, you address is sat on the desktop of my machine at work. will try to get it posted tomorrow.
  18. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I was going to used some threaded stud that you can get from good DIY shops comes in meter lengths. I was going to use this to mount the fan to the rad. If the diameter is to be big I was going to drill out super glue the studs and so on. Once this is done and the fan mounted I will make the shroud out of cardboard as a template and then use fibreglass or carbon fibre not decided.
    As always will keep you posted.
  19. George
    George Bah
    14 May 2002
    so, i will need zip ties to mount the 120mm fan case thing that Lucifer is very kindly sending me on with zip ties and then bolt my 120mm enermax on to the fan case thing, yea? no? lol...
    .icecube
  20. Lucifer
    18 Nov 2001
    it should be with you tomorrow morning, went 1st class.
    you owe me 41p :eeek: :lol:
