Electronics Few quick Electronics Q's?
Discussion in 'Modding' started by Tibby, 27 Nov 2006.
  1. Tibby
    Tibby Technologic
    9 Oct 2005
    Hey guys wondering if someone could quickly explain a few things to me.
    First off,
    How do you work out an LED power rating if it consumes 0.05A at 6v?
    Would it just be 6v@0.05A?
    And also how would you calculate the current from a 200W loudspeaker if the impedance is 8 Ohms?
    Cheers for any help guys!
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Power = V x I so, 0.05 x 6 = 0.3W
    The loudspeaker one is complex because the impedance changes with frequency (it's an impedance not a resistance). You can guess an approximate current knowing that P = I{param}R so that I = 5A, but it'll vary from that figure a fair bit.
  3. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    You can also deduce quite a lot if you know the resonant frequency of the speaker.
    For example if the res freq is 50Hz:
    I assume the supplied impedance is the lowest impedance for that speaker. That would happen only at the res freq because as impedance is defined by
    Z = ( R^2 + ( XL - XC )^2 )^½
    At res freq XL = XC. This leads to Z = R = 8 ohm.
    U=RI --> U=ZI and P=UI --> P=ZI^2 --> I = (P/Z)^½
    Thus the current would be I = ( 200w/8ohm )^½ = 5 A
    So the current is 5A as stated by SteveyG. But this is only so at resonant frequency. If the frequency changes the XL and XC kick in increasing the impedance. This in turn drops the current. So the 5A is your maximum current.
  4. Tibby
    Tibby Technologic
    9 Oct 2005
    Cheers guys,
    Thanks for clearing things up!
    Don't suppose someone could tell me what the amplitude of a Sine wave at 50Hz and 230V ac voltage taken from a household mains is?
    Also what the period of the given waveform would be?
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Tibby, isn't it about time you started doing your own homework? Or paying attention in class? :search:
  6. ch424
    ch424 Design Warrior
    26 May 2004
    So you're now at uni, and can't do GCSE physics?
  7. SteveyG
    23 Nov 2002
    That one gave it away that it was homework :hehe:
  8. Tibby
    Tibby Technologic
    9 Oct 2005
    I canna do it captain!
    I get soo confused, and this one kinda snuck up on me.
    Normally I get one of my class mates to come over and explain it to me, but it was due at 4pm today so was desperate!
  9. NoMercy
    NoMercy New Member
    23 Nov 2004
    I did both GCSE and MEng Electronics, and I'd say most degree students can't remember the GCSE electronics/physics much either, the glorious result of 20 years of education 'teaching to the exam'.... of course it's not the booze.
    Being able to find out and apply knowledge is more useful than remembering it though, espically when there's too much to remember for most mortals.
