Modding fibre optic question
Discussion in 'Modding' started by ido, 1 Aug 2003.
  1. ido
    ido What's a Dremel?
    12 Sep 2001
    I'm just about to do the fibre optic mod to my drives, but I was wondering if you guys still use a 3mm LED for the drive when you change the color. It seems damn near impossible to perfectly drill a hole from the top on a 3mm one. Do you guys switch to a 5mm LED? If not, any tips on drilling precisely?
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Personally, I just left the little bit of plastic in the drive front, which is much bigger for lining up teh optical cable. :D
    Switching to a 5mm would be fine, it's a matter of will it fit. And that the 5mm may give off to wide an angle and light the area to much. Otherwise drill very, very slowly. ;) If you've got a little hand/hobby drill that works very well.
    Though I never changed mine, as my burner came with a blue one :D and my DVD drive has no LED. I don't know how it lights up, there isn't an LED or SMD there either. The piece of plastic goes to a blob of solder that somehow emits orange light. :worried:
    Meh. :p
  3. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    photo of the blob of solder :D
  4. Kargin
    18 Sep 2002
    If you think I'm pulling my computer apart for that, your dreaming. It's hidden behind everything, screwd in and I ahve to remove so much just to get it out. I think not.
    But I can help you.
    Imagine this :
    A piece of green PCB, then imagine some tracks running on it, now imagine a blob of solder on one of those tracks.
    :D
    :p
