Graphics Fifa 2005 problems
Discussion in 'Hardware' started by tigra, 6 Nov 2004.
  1. tigra
    tigra What's a Dremel?
    23 Oct 2004
    i have fifa 2005 it worked fine!
    my video card Nvidia gforce mx 440 64
    i updatet my video drivers
    since then my fifa 2005 screen flicks
    what can i do abaut it
  2. DDP
    DDP What's a Dremel?
    22 Nov 2004
    I have similar problem. I have changed my video card. I had no problems before playing FIFA 2005, NFSU and NFSU2 with my card at 64MB but now I use NVidia GeForce FX 5500 128MB and the video of the games flicks. I use the driver from the CD of the card /ver 6.1.7.6/ and still haven't updated it, because I have heard that some games go better with older driver. Do I have to try updated driver or there is any way to solve the problem with settings ?
    Thanks!
  3. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Monitor refresh rate problems ?
    Or you could try playing Winning Eleven 8 or Pro Evolution Soccer for the PC :D
  4. DDP
    22 Nov 2004
    :) It's not because of a game.
    It's not a problem to play the games this way. It's a little irritating but it's possible to play - it just freeze the picture for parts of the second. But what I want is to get the best from my video card. And I want to know if there are some settings this to be done or I have to try with newer driver version.
    Thank you!
  5. Tim S
    Tim S OG
    8 Nov 2001
    I would suggest going to NVIDIA.com and downloading the latest drivers - ForceWare 66.93. :)
  6. DDP
    22 Nov 2004
    66.93 is not the latest. I found also 67.02 and 70.40beta but 66.93 is the one from the offical site of NVidia and my idea was it to be the next thing I will try. So... thanks for your suggestion - it helped me to have less hesitations :D
    I will write when I have any result :)
  7. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    Refresh rates? There's plenty of programs out there to lock refresh rates - powerstrip, refresh lock, reforce, nvrefresh tool, setting in nvidia drivers?
    I use refresh lock myself
  8. tigra
    23 Oct 2004
    wierd i deletet the updates of my video card and the game works fine again
    GFORCE 4 MX 440 SUUUUX
